4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Dec 2, 2023 at 2:46 PM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    Great autocorrect. :D
  2. Dec 2, 2023 at 2:50 PM
    woodsy
    Ohio
    This forum is a microcosm of society in general.
  3. Dec 2, 2023 at 3:05 PM
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    It’s a great platform to build off of. With 33’s a 2inch lift, amor, and arb lockers, you will be able to tackle some serious trails. It has good running clearance, a strong front diff, and great amount of rear wheel articulation. They are still small and relatively light compared to other trucks. They are also tough. I’ve lost amount of times I’ve of buried the truck up to the frame in mud, snow, caught the frame on rocks and other obstacles. They can take a beating.
    The ability to easily clear 33’s, a sway bar disconnect, and a larger rear diff will be welcome additions. The new linked rear will offer a much better ride on rough trails and in general. We will lose a little running clearance due to the new seating position, and we will lose a good amount of break over angle. Hopefully that can easily be countered with a lift and larger tires. I would feel more comfortable running 35’s with the higher torque, stronger differential and beefier CV’s. Hopefully they figure out a way to maintain the same amount of the rear flex. The c channel frame really helps with flex at the expense of twisting the bed apart over time. The new tundra lost a significant amount of rear articulation.
  4. Dec 2, 2023 at 3:16 PM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    So Turbo 4 even with an 8-spd transmission only gets slight increase in mpg. MPG might have been a little better if the HP/Tq were closer to outgoing engine, with Tq at a lower rpm it still would have felt faster. The problem is, ICE efficiency is near its peak. The power required to move heavy vehicles is going to require more or less the same amount of gas regardless of the configuration.
    On the other hand, EV/battery technology keeps getting better. The Cyber Truck uses 48V for accessories and 800V for the motors which is more efficient allowing thinner/lighter wiring and faster charging.
    Using a "giga press" to make light weight/low cost chassis castings may result in odd looking vehicles but the uni-body CT can tow 14,000lb so you can't say it's a weak design.
    If this BEV Tacoma, equipped like a PRO/TH, had HP/Tq similar to the T4 iForce Max and had 400mi range, I would pay $70K for it.
  5. Dec 2, 2023 at 3:38 PM
    DRAWN
    If they can figure out range I would be sold. Range is still questionable though. 340 miles for the CT, and that’s before towing/ heavy payload variable driving conditions and cold weather. With battery tech advancing at its current pace why not hold off a couple years. Lighter batteries that charge faster while giving us better range seems inevitable. It will be interesting to see how manufacturers implement them. Tesla uses their batteries as core structural support. That seems like a bad idea to subject an off-road vehicle to that. BOF design is still ideal as it can handle a fairly severe amount of force from the truck flexing over uneven terrain. Allowing that force to flex into the battery pack, the most expensive component in the vehicle, is a little questionable.
    SwollenGoat likes this.
  6. Dec 2, 2023 at 4:12 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    It's indeed equipped like a Pro, including the TRD exhaust system:
    shakerhood[OP] and Turd Ferguson like this.
  7. Dec 2, 2023 at 4:14 PM
    It's a TRD Thang
    It's a TRD Thang Well-Known Member
    Canada
    2021 Army Green Off Road
    3 inch Leveling kit with 265 75 r16 Ko2's
    That was a gasser made a EV concept....it wasn't a real EV..... it was the 4th gen in plain sight
  8. Dec 2, 2023 at 4:22 PM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Maybe autocorrect............ maybe not :D
  9. Dec 2, 2023 at 4:45 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
  10. Dec 2, 2023 at 4:45 PM
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    As soon as I saw that model I called 4th gen Tacoma
  11. Dec 2, 2023 at 7:54 PM
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Thought enthusiasts love to nit pick? Otherwise there would be no enthusiasts, yeah? :)
    https://www.youtube.com/watch?v=9NH87JoJ8Pk
    mikekoot likes this.
  12. Dec 3, 2023 at 5:27 AM
    ReubenSandwich
    ReubenSandwich Lithuanian Goodness Between 2 Slices Of Rye
    burnttaco7 and 3JOH22A like this.
  13. Dec 3, 2023 at 7:02 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
  14. Dec 3, 2023 at 7:28 AM
    It's a TRD Thang
    Canada
  15. Dec 3, 2023 at 7:47 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Jeff Bezos denies direct linking. You have to go to the page and download the PDF: https://pressroom.toyota.com/vehicle/2024-toyota-tacoma/
    It looks like the same spec sheet the press got on Nov 21.
    Turning radius of 4th gen DCSB is about the same as 3rd gen DCLB. Steering rack ratio is about the same, but 4th gen has 3.3 turns lock-to-lock vs. 3.6 turns on 3rd gen for 4x4 TRD trims.
  16. Dec 3, 2023 at 7:58 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Whats the reverse ratio on the 3rd gen? Just curious if they addressed that handicap. It would be nice to not have to use 4lo to back up.
    Found it I think,
    '24
    '23
    CCATT-RN likes this.
  17. Dec 3, 2023 at 9:31 AM
    Plasmech
    Plasmech Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    Holy F-bombs, we have a spec sheet!
    ...with specs on it!
    BirdBrain likes this.
  18. Dec 3, 2023 at 9:44 AM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    So, the lows get lower and the highs get higher. Will be interesting to see/feel the difference. The taller 6th might help highway fuel consumption because of the lower engine speed.
    Lt. Dangle[QUOTED] likes this.
  19. Dec 3, 2023 at 9:47 AM
    ReubenSandwich
    @Lord Helmet, @It's a TRD Thang, @3JOH22A
    I can assure you, it's real. In typical Toyota fashion, its got some errors..... 12.8 quarts of oil for the T24A? I thinketh not..
    and @3JOH22A , thank you I didn't know that would cause a problem. Sorry everyone.
  20. Dec 3, 2023 at 9:51 AM
    Plasmech
