4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Jan 26, 2023 at 4:04 PM
    #1881
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    If they make the '24 Taco turbo easy to change and labor friendly where I can change the turbo without removing the cab or engine, then we might be off the hook. We'll have to see.
  2. Jan 26, 2023 at 4:07 PM
    #1882
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    I love turbos too, on a sports car. Not on a truck though.
  3. Jan 26, 2023 at 4:09 PM
    #1883
    Turd Ferguson
    Taxachusetts
    I’m sure this will affect resale value too. Who wants to buy a well used turbo truck with no maintenance record with a ticking time bomb turbo.
  4. Jan 26, 2023 at 4:11 PM
    #1884
    Turd Ferguson
    Taxachusetts
    Doesn’t the current Tacoma have mini van specs? :D
    Dirty Harry likes this.
  5. Jan 26, 2023 at 4:12 PM
    #1885
    The hammer
  6. Jan 26, 2023 at 4:12 PM
    #1886
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    uh, no.
    :rofl:
    The hammer likes this.
  7. Jan 26, 2023 at 4:13 PM
    #1887
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    In the video it states you can remove the turbocharger without having to remove the engine.
    The hammer[QUOTED] likes this.
  8. Jan 26, 2023 at 4:14 PM
    #1888
    The hammer
  9. Jan 26, 2023 at 4:16 PM
    #1889
    Turd Ferguson
    Taxachusetts
    Meanwhile the Frontier can beat those numbers with a V6.
    Dirty Harry and The hammer like this.
  10. Jan 26, 2023 at 4:16 PM
    #1890
    The hammer
    But unfortunately, the turbo on the video is not a taco. We have to wait and see if the knuckleheads engineers will do the right thing on the truck
  11. Jan 26, 2023 at 4:17 PM
    #1891
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    A properly maintained turbo will last as long as most non commercial engines 150-250k miles. So why does it matter at 250k miles you’ll have bigger issues than turbo itself
    Horseshoez and DRAWN like this.
  12. Jan 26, 2023 at 4:20 PM
    #1892
    The hammer
    Because the turbo is the nail on the coffin to a slew of issues already piling up
  13. Jan 26, 2023 at 4:20 PM
    #1893
    Turd Ferguson
    Taxachusetts
    Without removing the engine? Those engineers should get a medal for that. You probably just have to take apart 80% of the engine bay.
  14. Jan 26, 2023 at 4:22 PM
    #1894
    Turd Ferguson
    Taxachusetts
    You need to change “will” to “might”. Plenty of turbos fail well below 150K.
  15. Jan 26, 2023 at 4:23 PM
    #1895
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Remember in a 4 cyl truck application, that turbo is going to be worked hard. It's a lot of weight for a 4 cyl to push. It's going to need a good amount of boost to make enough power. Turbo technology has gotten pretty damn good but I really don't see them regularly lasting 200k. Thats a long time for something to spin at 100,000 rpm+
    And let's not forget about what happens if a turbo really let's go and sends metal shaving into the intake and blows up the motor.
  16. Jan 26, 2023 at 4:42 PM
    #1896
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    In a longitudinal layout with a 4-cylinder in an engine bay as large as the Tacoma's, I would seriously doubt there will be much in the way of getting the turbo out (from the chassis, who knows what else on the engine itself will stand between you and the turbo).
    Jeff
    Johnny919 and Canadian Caber like this.
  17. Jan 26, 2023 at 4:46 PM
    #1897
    Johnny919
    Long Island, NY
    I'm not sure how extensive it is, I'm sure there is some work involved. The hammer asked if you had to remove the engine and the answer is no.
  18. Jan 26, 2023 at 4:51 PM
    #1898
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    While replacing a turbo is expensive it’s not necessarily a deal breaker these days. I spent a similar price to replace my transmission seal which failed at 160k. other owners have spent far more on timing cover leaks. I love the 3.5 but it’s gutless and you need to work it hard when loaded down or towing. I can’t see it lasting over 350k-400k miles. I’m a high Mileage driver and it’s taken me 7 years to put over 170k on my 16. Realistically how many taco owners will see over 300k? I think it’s a small number. By the time you get to 300k miles you will spend thousands replacing ball joints, UCAs, shocks, leaf springs, tie rods, maybe a steering rack, u joints, maybe a wheel bearing or two. With the 2.4t we are getting just what the taco needs. A small efficient engine that makes great low end torque. Add a hybrid max setup and it will be a better performing motor than the Tacoma has ever had. Not to mention engines designed around turbos are actually stronger than comparable NA engines. There are plenty of examples of turbo charged Lexus engines rolling over 200k with no turbo issues.
  19. Jan 26, 2023 at 4:53 PM
    #1899
    Johnny919
    Long Island, NY
    He said in the video there is the possibility you may have to pull the drive shaft, around the 9 minute mark.
  20. Jan 26, 2023 at 5:05 PM
    #1900
    Jeff Lange
    Calgary, Canada
    That’s not a longitudinal arrangement in a body-on-frame truck, so things are a little more cramped.
    Jeff
