4th Gen Tacoma OEM wheels on a 3rd Gen Tacoma
Discussion in 'Wheels & Tires' started by finndago, Nov 17, 2024.
  1. Nov 17, 2024 at 5:07 PM
    finndago
    finndago [OP] Member
    Just wondering if anyone has installed 4th gen wheels (Taco) on a 3rd gen (taco) heard hub is different (smaller) for 2024 and lug pattern the same.
  2. Nov 18, 2024 at 11:12 AM
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    They won't fit unless you open the center bore at a machine shop.
    4th Gen Hub = 95.1mm
    3rd Gen Hub = 106.1mm
    finndago[OP] likes this.
  3. Nov 19, 2024 at 1:57 PM
    hemlockz
    hemlockz Well-Known Member
    24 Bronze ORP 6MT
    Anyone know if that machining has actually been attempted? I've heard this suggested a few times. Wondering if it ever has happened...
    And in would the wheel clear inside the suspension as the 4th gen wheel has a more positive offset
    And the lugs on the 4th gen are larger too so to get it centered you'd necessarily need the machining to be a perfect fit to 106.1mm too
    TrdSurgie and finndago[OP] like this.
  4. Nov 19, 2024 at 2:55 PM
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    @hemlockz the Pro or Trailhunter offset would be your best bet. Still high though. I think the easiest way is to get a set of BORA adapters made. They would take care of the hub bore, offset and stud issue since they're custom made.
