4th Gen. Tacomas (2024+) Spy Shots
Discussion in '4th Gen. Tacomas (2024+)' started by 3JOH22A, Oct 5, 2021.
  1. Oct 21, 2021 at 7:29 PM
    #361
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    Rumors are the next gen 4runner will share the same powertrain as the next gen tacoma.
    BC Hunter and Junkhead like this.
  2. Oct 21, 2021 at 7:46 PM
    #362
    Chicken_Taco
    Chicken_Taco Well-Known Member
    Comfortably numb on the Darkside of the moon
    2019 Midnight Black Tacoma TRD Sport
    Working on it ...
    I came within a pubic hair of buying a 4Runner this go round when I bought my Tacoma. At the end of the day I guess I was still just a pick up truck sort of guy. This is my fourth one, but I suspect in 10-12 years when I’m ready to replace this I will be ready for a 4Runner by then.
  3. Oct 21, 2021 at 8:05 PM
    #363
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    We have both. At this point the Tundra and Tacoma developments are certainly interesting for folks wondering about the 4Runner. Should be interesting now that the Bronco finally launched.
    Junkhead likes this.
  4. Oct 21, 2021 at 8:18 PM
    #364
    Maxx
    Maxx Well-Known Member
    It’s likely not the fuel blend change reducing your fuel economy. It has cooled down which means the intake air charge is denser which means the ECU compensates with more fuel to maintain the target air fuel ratio. More air, more fuel, more timing, more power, lower fuel economy.
  5. Oct 21, 2021 at 8:29 PM
    #365
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    The new 4WD Tundra is rated 17/22. Most test runs I've seen posted are 19.5ish MPG. Hybrid should gain 4-5 MPG. Certainly an improvement over the horrendous 13/17 of the old truck, but I think Toyota had to do better given the full-size competition. They really need to get it right with the Tacoma; its much more relevant to their bottom line than the Tundra.
  6. Oct 22, 2021 at 12:14 AM
    #366
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    17/22 isnt enough imo. Ford and Ram both have those numbers with there V8s
    Malvolio likes this.
  7. Oct 22, 2021 at 11:56 AM
    #367
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    I hope the back windows is still a sideways slider instead of one that rolls down........so everyone still has something to bitch about.
    Malvolio and ManInTheMaze like this.
  8. Oct 22, 2021 at 12:03 PM
    #368
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Great now I have to look for a rear drum conversion kit. :facepalm:
    Lt. Dangle, Junkhead and Malvolio like this.
  9. Oct 22, 2021 at 12:49 PM
    #369
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    #birdsarentreal
  10. Oct 22, 2021 at 1:02 PM
    #370
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    4th gen Tacoma, should be renamed 4Runner Utility or 4Runner pickup. Toyota won't ditch the Tacoma brand, but something different would be cool. 4Runner could become it's own brand from Toyota, if all those vehicles came with a manual transfer case, that eould help the brand image.
  11. Oct 22, 2021 at 1:04 PM
    #371
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
  12. Oct 22, 2021 at 1:41 PM
    #372
    sporin
    sporin Well-Known Member
    Dave
    Vermont USA
    '21 Tacoma TRD-Offroad
  13. Oct 22, 2021 at 2:25 PM
    #373
    CrispyTacoLover
  14. Oct 22, 2021 at 3:47 PM
    #374
    GrievousAngel
    GrievousAngel Well-Known Member
    2019 Tacoma SR 4x4 V6 DCSB Super White
    No one likes disposable. You still see 1st gen tacomas and earlier running everywhere. I doubt the ones we have now (dual fuel injection, iffy transmissions) will last like them. But adding turbos to small displacement motors, auto-stop motors, and hybrid drivetrains? No thanks. Hope mine lasts a long time. Vehicles have become so bastardized to meet average fleet mileage. I'd rather have a full electric truck over these overwrought designs they're coming out with to make ICEs "work."
  15. Oct 22, 2021 at 5:28 PM
    #375
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I can tell you you definitely don't see a lot of 1st gens and older where I live. They've all rusted out. But I can appreciate one when I do see it.
    Anything will last if you take care of it. Yes, vehicles are a little more complex today but they're also generally more reliable.
    As for turbos, it just depends on the engine. If it is an engine with a turbo slapped on, it isn't good. If it is an engine designed around the turbo it is much better. If they were so bad Ford (among others) wouldn't keep selling them because people wouldn't keep buying them. Toyota certainly wouldn't be going down that path either. The most common issues I see with said engines rarely have anything to do with the turbo (or head gaskets, etc) and are things any engine can have issues with. Let's ignore the fact that people had the same concerns when they added turbos to diesel engines back in the day but now it is extremely common and those engines routinely see extremely high miles.
    As for auto start/stop, that's usually not much of an issue either outside of noticing your car shut off. The big worry with those was people thinking it put undue stress on the starter. Most start/stop systems I've seen don't even use the starter and instead stop the engine in the right spot to start back up using the fuel injection system. As for hybrids, that is even less of an issue. In most cases you have no clue weather the car is using the engine or not unless there's an indicator light.
    As for "iffy transmissions." The 3rd gens have a lot of complaints about the way it shifts but I have yet to see failures related to it, let alone common ones. A lot of what it boils down to is driving style and not being used to something that is optimized for MPG. We're not in the days of the 3 and 4 speed transmissions anymore.
    As for electric cars, I agree. In a roundabout way they are much simpler and, not withstanding computer components wearing out, will be much more reliable. Although cars have had computers for decades and they do last.
    DRAWN and Junkhead like this.
  16. Oct 22, 2021 at 5:51 PM
    #376
    Gnarman
    Gnarman Well-Known Member
    Southwest
    2016 dbcb trd off road quicksand lb
    ARB Shell, BP51, 255/85/16 ST MAXX, SCS Ray 10 Matte Bronze, Caliraised led 32 inch/side shooter/amber pods, floor mats, start x remote start, auxbeam 8 gang switch panel, diode dynamics hid lows, Australian Shepherd
    I have both 4runner interior shits on my 2016 Tacoma lol
  17. Oct 23, 2021 at 3:54 AM
    #377
    RedWings44
    Michigan
    Just depends on your perspective. We also have both. My wife and I both prefer the Tacoma interior (minus the larger cupholders on the 4Runner). The Tacoma is more modern on the inside as well.
    DRAWN, Junkhead and SwollenGoat like this.
  18. Oct 23, 2021 at 7:25 AM
    #378
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Had my 1st Gen for the past 19 years, 434K on the clock, timing belt every 90K, clutch at 130K, then it didn’t start nickel and diming me until 250K, which was great. Every failure has been a mechanical one, nothing electronic has ever caused an issue, other than a fuel pump. Anything will last if you’re willing to keep throwing money at it. Believe there is a misconception that the old trucks are super reliable, they are to a point, and even then it needed major repairs early in its life. Usually it costs me $1000-1500 a year to keep it going, this year was the worst, tossed $6000 at it. Seemed like every other month something would break. And still needs a few things. Could easily toss another $5-6K at it. My wife finally stepped in and said enough is enough, just buy a new truck…so I decided to throw in the towel and did.
    I resisted all of the electronic Gee-gaws for years, but rather enjoying them now. I may not go as long this go around, and trade in every 5 years instead. A hybrid Tacoma peaks my interest more than full electric, only because the infrastructure is quite lacking at this time here in Idaho. Be ok for commuting, but kinda screwed for my back country trips.
  19. Oct 23, 2021 at 9:35 AM
    #379
    Gnarman
    Southwest
    I have a trd off road base Tacoma too without seat heaters or dual climate control
  20. Oct 23, 2021 at 9:46 AM
    #380
    RedWings44
    Michigan
    I have both of those things. Although our 4Runner does not. But I didn't factor those into my preference.
