4th Gen. Tacomas (2024+) Spy Shots
Discussion in '4th Gen. Tacomas (2024+)' started by 3JOH22A, Oct 5, 2021.
  1. Oct 5, 2021 at 2:48 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I was factoring that in. I think the frame clearance is less.
    My SWAG is that they're going the Ford / GM route and having lower trims and lifted trims?
    Just for argument's sake:
    BigMack and Junkhead like this.
  2. Oct 5, 2021 at 2:54 PM
    3JOH22A
    3JOH22A [OP] トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Looks about the same to me, red line crosses at the lower edge of the center hub cap:
    2020_toyota_tacoma_extended-cab-pickup_sr5_s_oem.jpg 2342651cb5d7b09fcd45419260e5b31e_l.jpg
    I think the 4th gen has a bloated whale of a body that's taller and longer. At least the larger wheel arches may be able to accommodate bigger tires with less trimming. :)
  3. Oct 5, 2021 at 2:58 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good comparo.
  4. Oct 5, 2021 at 3:01 PM
    Pinion
    Pinion Well-Known Member
    Drew
    Brookings Oregon
    2020 DCSB limited 4x4
    Looks a lot bigger
    Are we sure this isn’t a tundra
    Abject4x4, YMMPRO, YF_Ryan and 4 others like this.
  5. Oct 5, 2021 at 3:11 PM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    Looks like it has a diesel in it. :anonymous:
    TacoSteve1234, bzzr2, TRD-ED and 11 others like this.
  6. Oct 5, 2021 at 3:12 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
  7. Oct 5, 2021 at 3:14 PM
    TomTuttle2019
    TomTuttle2019 Well-Known Member
    Jack
    Colorado Springs, CO
    '19 Black SR5 V6 Access Cab
    Pro grille
    that's definitely a door handle on that back tiny door. Love the suicide doors on my AC
  8. Oct 5, 2021 at 3:24 PM
    Tacos03
    Tacos03 Well-Known Member
    Summit
    2018 TRD OR DCLB
    I hate to say it but isn’t this a access cab 2022 tundra looks exactly like it. I understand they may scale it down to the Tacoma line up but the “camo” looks exactly the same as the tundra.
  9. Oct 5, 2021 at 3:42 PM
    vaca
    vaca Well-Known Member
    PA
    2020 SR DCSB 2.7 2WD
    Do we know for sure what model year the Gen 4 will be? 2024? Any chance that test mule might be a Gen 3 refresh for maybe 2023?
  10. Oct 5, 2021 at 3:46 PM
    3JOH22A
    District 6ix
    4th Gen. is expected to debut as 2024 model year, appearing mid-2023, according to several sites. I don't think Toyota will invest heavily in the 3rd gen with less than a couple of years left, most likely just new colors, new wheels, new tail light pattern, reshuffle of accessory packages, etc.
    The Tundra has a double cab model that's longer/wider in proportion to the wheels:
    The camouflaged Tacoma is noticeably shorter between the cab and the rear wheel arch:
    I wouldn't be surprised if the test mule has Tundra body panels on a shortened frame with narrower axles.
    Carmaker1 likes this.
  11. Oct 5, 2021 at 4:11 PM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Tundra and Tacoma will share the same frame, which to me, means the same suspension. Could a common frame accommodate both leaf springs and coils?
    Slashaar likes this.
  12. Oct 5, 2021 at 4:38 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    That would make too much sense for toyota to do, so they'd never do it.
    grogie and barf like this.
  13. Oct 5, 2021 at 4:46 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Rear non-suicide door is wider than 3rd gen access cab doors.
    Mud flaps at very back of bed go all the way across and look flappy (seriously what are they hiding with the flappers).
    Wheels blurry indicate the truck is moving.
    Guy driving in pic below is wearing sunglasses.
    Details gentlemen, details. :rolleyes:
    Atl-atl and shotgunbilly420 like this.
  14. Oct 5, 2021 at 6:55 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    That's the #1 reason why I bought an AC
  15. Oct 5, 2021 at 7:03 PM
    #35
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    The proportions looks like a mini tundra and I don’t mean that as a compliment.
    Gamma11, barf, Thunder Fist and 2 others like this.
  16. Oct 5, 2021 at 7:07 PM
    #36
    Mad German
    Mad German Well-Known Member
    2016 TRD Off Road
    But drum brakes are so much better off road and superior to discs…:rofl::D:p
    grogie, Stocklocker and Steadfast like this.
  17. Oct 6, 2021 at 3:10 AM
    #37
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    What I am seeing in all the pics is that the driver is sitting much lower than in the current models. Our trucks have lots of side to side room. But are kinda tough to get into. With the steering wheel all the way up, I rub it getting in all time. I would say there is more room inside now, with better seating...if this is a new 24 Tacoma.
  18. Oct 6, 2021 at 4:24 AM
    #38
    ascendr
    ascendr Active Member
    I took a shot at this, def not a photoshop expert though
  19. Oct 6, 2021 at 4:40 AM
    #39
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    If it looks like the new Tundra, I won't like it at all... Just too much grille.
  20. Oct 6, 2021 at 4:44 AM
    #40
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Looks like Toyota is going the route that Honda did with the new civic that looks like it’s big brother the accord . So I guess the Tacoma will look similar to the new tundra .
