4th gen trd off roadn shocks fit 3rd gen rear?
Discussion in 'Suspension' started by JDKred, Jun 23, 2025.
  1. Jun 23, 2025 at 11:43 AM
    JDKred
    JDKred [OP] Well-Known Member
    JD
    16 MT KDMax Tuned
    Will the 4th gen trd OF rear shocks fit the 3rd gen?
    Seems they are a "better" shock and could be a curious test
    GTGallop likes this.
  2. Jun 23, 2025 at 12:16 PM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Subbed to find out more.
    JDKred[OP] likes this.
  3. Jun 23, 2025 at 12:21 PM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    I wondered the same thing but haven't been able to find any specs.
    Also curious if any of the GX550 suspension components could be interchanged. They lengthened the front lower control arms and CVs to increase suspension travel. Would be interesting if those components could be adapted to fit a Tacoma.
  4. Jun 24, 2025 at 8:11 AM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    Them fitting is kinda irrelevant (even though im pretty sure the mounting bolts are different sizes and the total shock length is different). Even if you could get them to fit, it's a completely different suspension setup. There's a very good chance they will make the ride worse on a 3rd gen. The valving won't match the leaf spring setup of the 2nd/3rd gens.
  5. Jun 24, 2025 at 12:34 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I think it could be worth trying if the shock actually physically fits... The suspension's motion ratio should be very close to the same (1:1) since both are a solid axle, and I suspect the truck's weight isn't too far different either.
    I do suspect the shock mounting (and/or it's length) would be different though.
    OEMs seem to have this thing with not using an existing item (such as shock mount configuration) for a redesigned vehicle even in cases where that existing item would've been perfectly fine to use (I guess to keep aftermarket companies on their toes? Kindof sucks really... The changed lug/hub pattern & offset for 4th-gen wheels is a good example of this).
