4th Gen trip odometer
Discussion in '4th Gen. Tacomas (2024+)' started by DRB777, Aug 2, 2024.
  1. Aug 2, 2024 at 8:42 AM
    DRB777
    DRB777 [OP] Well-Known Member
    David
    2024 Tacoma SR5 4X4 double cab
    None so far
    Is there an easy/quick way to reset the trip odometer on the new 4th gen?
  2. Aug 2, 2024 at 8:59 AM
    patos tacoma
    patos tacoma Well-Known Member
    You mean like pressing a button just once…….no………must go thru many menus…….
    rchrds likes this.
  3. Aug 2, 2024 at 9:38 AM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    Not sure about on the 7-inch display for on the 12-inch it's not bad once you do it a few times.
    Use arrows to toggle to the screen with the trip odometer you want to reset.
    Hold OK button down until the select brackets pop up.
    Use arrow button to select the trip odometer.
    Hold OK button down to reset.
    Use back button to return to normal operation.
    funkchild and DRB777[QUOTED][OP] like this.
  4. Aug 2, 2024 at 2:06 PM
    Motor Away
    Motor Away Well-Known Member
    Anyone know if the 2024 Land Cruiser suffers from this same design flaw?
  5. Aug 2, 2024 at 8:23 PM
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    I was shocked to find out that yes, this craptacular process is indeed the only way to do it.
