4th gen will come with manual
Discussion in '4th Gen. Tacomas (2024+)' started by suprafastcelica, May 2, 2023.
  1. Aug 14, 2023 at 8:43 AM
    #201
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Trailhunter and PRO come with hybrid, no option there. But the other TRD trims you can get either engine option.
    Jeff Lange and shakerhood like this.
  2. Aug 14, 2023 at 8:59 AM
    #202
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    They already announced the manual will be available in the SR, TRD Sport, and TRD Off Road.
    radclerk1 and Tacospike like this.
  3. Aug 14, 2023 at 9:10 AM
    #203
    Qtrpound3r
    Qtrpound3r Member
    Boise, ID
    ‘18 TRD ORSB MT
    noted. I must’ve misunderstood the options when I read/watched the release. Nevertheless, it seems there will be greater customization with the NA V6 vs. the forced induction I4.
  4. Aug 14, 2023 at 9:26 AM
    #204
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Not sure where you got that idea, but turbocharged engines are typically easier and less expensive to customize than NA engines, V6 or otherwise.
  5. Aug 14, 2023 at 9:46 AM
    #205
    Qtrpound3r
    Qtrpound3r Member
    Boise, ID
    ‘18 TRD ORSB MT
    how so?
  6. Aug 14, 2023 at 9:49 AM
    #206
    Qtrpound3r
    Qtrpound3r Member
    Boise, ID
    ‘18 TRD ORSB MT
    adding a supercharger to the 3.5 L V6 yields greater output than a turbo 4. There’s no replacement for this placement.
  7. Aug 14, 2023 at 9:55 AM
    #207
    Horseshoez
    Dale
    Maryland
    Adding a supercharger to the V6 is an expensive endeavor. The old, and often debunked adage about displacement is a worthless argument.
    I would argue an equal amount of money put into the Turbo-4 and the V6 will allow the smaller displacement engine to both outperform the larger one in virtually every metric, including longevity.
    Hogleg918 likes this.
  8. Aug 14, 2023 at 10:00 AM
    #208
    Qtrpound3r
    Qtrpound3r Member
    Boise, ID
    ‘18 TRD ORSB MT
    geumble grumble. You think pushing or pressure through a smaller engine to yield the same output of less pressure in a larger engine isn’t going to add more stress and increase likelihood of failure?
  9. Aug 14, 2023 at 10:01 AM
    #209
    Qtrpound3r
    Qtrpound3r Member
    Boise, ID
    ‘18 TRD ORSB MT
    for someone who has a corsair as their profile icon I would assume you know better than to think higher pressure systems are less likely to failed and lower pressure systems.
  10. Aug 14, 2023 at 10:05 AM
    #210
    deezyc
    deezyc Well-Known Member
    Keep the manuals alive.
  11. Aug 14, 2023 at 10:21 AM
    #211
    Horseshoez
    Dale
    Maryland
    It seems you are making the naïve assertion both engines were designed and stressed for the same amount of output per unit if displacement; sorry, incorrect. The fact is, engines designed from the factory for turbocharged applications are designed to allow power production per unit of displacement many times that of engines designed to be normally aspirated.
  12. Aug 14, 2023 at 12:06 PM
    #212
    joeR6
    joeR6 Active Member
    2022 TRD OR M/T
    Much easier to tune a turbo charged engine. I'm sure the aftermarket tuners will be all over this I4 engine once it comes out. But yes adding more power from the engine will just stress something else down the line. I know that VW MK7 GTIs even at a stage 1 tune the stock clutch would start to slip as the stock clutch couldn't handle the power, necessitating a beefier clutch/flywheel = more $$$ to spend.
    Will be interesting to see how Toyota does this with the manual option. Hopefully its the same power output as the auto tranny and not detuned as some other manufactures do with cars where they offer a manual (i'm looking at you Golf R)
  13. Aug 14, 2023 at 12:54 PM
    #213
    Qtrpound3r
    Qtrpound3r Member
    Boise, ID
    ‘18 TRD ORSB MT
    I think it’s an awesome upgrade for sure. Super interested in fuel economy with the new setup. I don’t have a dog in the fight anyway. Trading in my ‘18 6MT for a linear power curve rig.
  14. Aug 15, 2023 at 8:18 AM
    #214
    mistareeman
    mistareeman Well-Known Member
    Your Mom
    2019 ORDCSBMT4x4
    The manual does indeed have less power according to press release:
    270 horsepower and 310 lb.-ft.of torque
    and the auto with the same engine:
    278 horsepower and 317 lb.-ft.of torque
    They gave reasons for it in one of the videos, wondering how much people will push the power limits.
    doublethebass likes this.
  15. Aug 17, 2023 at 10:01 PM
    #215
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Over / Under on a manual gearbox w/ a 6’ bed?
    …..never gonna happen
    shakerhood likes this.
  16. Aug 18, 2023 at 4:28 AM
    #216
    Jleeb
    Jleeb Well-Known Member
    Vermont
    2017 DCLB OR SUPERwhite.
    Stock
    Is there a DCLB manual????
  17. Aug 18, 2023 at 5:28 AM
    #217
    radclerk1
    radclerk1 Well-Known Member
    Vic
    2017 Access Cab 2.7L Manual 4x4
    None
    Nope
  18. Aug 18, 2023 at 12:28 PM
    #218
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    Still holding out hope we will see the XtraCab manual here in Canada.
    specter208 likes this.
  19. Aug 18, 2023 at 1:12 PM
    #219
    Tacospike
    Two Trucks
    Hypothetically, if 5th Gen doesn't come in manual, you manual folks going to stop buying tacomas?
    NOTE: I didn't start a new thread :p
  20. Aug 18, 2023 at 1:43 PM
    #220
    radclerk1
    Vic
    None
    Yes, I’d stop buying new Tacomas. I’d love to have a pro, but since it only comes in auto now it’s off my list. The new 4Runner is coming out with a manual so I’m heavily leaning toward keeping my current Tacoma and adding a new 4Runner.
