4th gen will come with manual
Discussion in '4th Gen. Tacomas (2024+)' started by suprafastcelica, May 2, 2023.
  1. May 8, 2023 at 7:32 PM
    #101
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I would seriously doubt the veracity of the source of that information. Plugging in a different transmission and some different electronics doesn't even remotely rise to the level of "retooling the assembly line". That said, could Toyota build them in batches for logistical reasons? Yes, but I doubt it. When mine was built back in September I was tracking the influx of new Tacoma's via the Kissmygrits spreadsheet and there were no more 6MT models that week than at any week I have tracked before or since mine was built.
    specter208 likes this.
  2. May 9, 2023 at 4:37 AM
    #102
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    Curious, is yours a ‘22 or ‘23? Mine is a ‘22, also last September build. Arrived at the dealer in November (allegedly on a truck full of other 6MT’s), I believe fairly well after MY23 started hitting the lots which I thought was kind of unusual timing.
  3. May 9, 2023 at 4:42 AM
    #103
    Horseshoez
    Dale
    Maryland
    Mine was scheduled as a Week 34 build (which should have been in August) but it wasn't built until the second week of September; if I remember correctly, it was the penultimate week for the 2022 model years. I took delivery in mid-October and when it rolled off the truck with four other Tacomas, it was the only 6MT.
  4. May 9, 2023 at 6:03 AM
    #104
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    Lol... a manual transmission is probably 2 to 3 times as expensive to install... it's just as complicated to install and manufacture as an automatic. Except toyota can't buy them in the same volume so they are actually much more expensive then an auto. Then you have the plant assembly line. Seperate installers testers, downtime while switching ect ect... we only make up 5% of products. In a manufacturing world that is a major headache. That's why they strip things from the MT PRO to recapture some of the cost off set.
    In 1950 thru about 1970 an automatic was more expensive to build and install. No longer true
  5. May 9, 2023 at 8:59 AM
    #105
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The current MT runs $1830 less than it's AT counterparts, can't see it swinging the other direction for the 4th Gen.
    Gear Jamin Jamie and Hogleg918 like this.
  6. May 9, 2023 at 9:03 AM
    #106
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    It’s not that different but I guess I’m used to it (backing up that is).
    shakerhood likes this.
  7. May 9, 2023 at 11:35 AM
    #107
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    That's fair and Toyota is fairly hush hush about the whole process but when I was buying my pro they seemed to come out in certain batch intervals even the color spread seemed to be by region. I really wanted a manual in the calvary blue but every one I was finding were in the northeast and gulf coast regions. The might also have to keep the numbers low to qualify for EPA mpg averages or something who knows.
    Counterpoint: it's not only the transmission though its getting into the engine bay with the brake booster pump, the ECU's are different, removing crawl control, different audio speaker setups, and ignition keyed vs push button, the gearing in the auto vs manual is different. The list goes on...
  8. May 9, 2023 at 11:39 AM
    #108
    Horseshoez
    Dale
    Maryland
    The list goes on, but they are relatively trivial on a modern production line; absolutely no need to retool the line to intersperse AT and MT models on the same line.
  9. May 9, 2023 at 11:42 AM
    #109
    6MTPro
    HI -> CA
    Agreed but when you have 400k produced a year and they are running over 100% capacity every minute counts. If they're following Kaizen or something similar for production they want it to be as efficient as possible.
  10. May 9, 2023 at 11:42 AM
    #110
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    If retooling were the case, I guess my question would then be what is Toyota doing to screw up this process when nearly every other car maker has no issue pushing sticks and autos through on the same line?
    It really makes no sense to do a shut down and retool just for a transmission option.
  11. May 9, 2023 at 11:58 AM
    #111
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Call me crazy, but I have a hunch they might even use the Toyota Production System… :anonymous:
    CCATT-RN and Cetacean Sensation like this.
  12. May 9, 2023 at 12:16 PM
    #112
    6MTPro
    HI -> CA
    Kaizen is one of the core components of TPS. Without Kaizen TPS wouldn't be what it is.
    • 5S – Cleaning up to make problems visible and getting organized.
    • Kaizen – Continuous improvements through acting on suggestions.
    • Kanban – Demand pulls products through the production process, resulting in a just-in-time system of inventory and production.
    • Poka-Yoke – Mistake proofing.
    • TPM (Total Productive Maintenance) – Proactive and preventative maintenance done in a way that maximizes the productive operation of machines and equipment.
    • Visual Factory – Using visual labels, signs, tags, and other cues to improve communication
    https://www.graphicproducts.com/articles/toyota-production-system/
    Gear Jamin Jamie and ktbell444 like this.
  13. May 9, 2023 at 12:28 PM
    #113
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
    If it makes you feel better, I just got more than I paid for my 22' manual OTD in trade towards my 4runner. Got similar offers from Carvana to buy it. No seed to sulk. Get rid of it if you dont like it.
    I'm glad Toyota is keeping the manual. Hopefully they do a better job with the 4th gen powertrain and it's more of a pleasure to drive. I dont know if I'm getting old, lazy, or both, but I'm happy to be back in an auto. I don't think I'd buy another manual truck.
    Halibut likes this.
  14. May 9, 2023 at 12:45 PM
    #114
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    What are do you live in? I have gotten quotes out of curiosity of the easy out option, for my truck with all of 2,600 miles, they are offering $5-10,000 under sticker. This was an outright buy quote though, but I wondered if it might be regional influence as well since I keep hearing people get good offers through them.
  15. May 9, 2023 at 12:47 PM
    #115
    6MTPro
    HI -> CA
    A manual 4Runner would be a dream though...:spending:
  16. May 9, 2023 at 4:24 PM
    #116
    mwn
    mwn Member
    Humboldt County, CA
    2023 Space Dirt Tacoma TRD Sport ACLB M/T
    Interesting. Anticipated lack of a manual in the 4th gen. was certainly part of the reason I bought a '23 instead of trying to eek out another year with my ailing van. Another factor was not wanting to deal with "bugs" that can accompany the first model years of a refresh or redesign. But, I've had my truck since December and have no regrets after reading this news: good on Toyota for keeping a three-pedal truck on the market here! Now, if the 4th gen. gets 30 mpg (or whatever) with the manual . . . there might be some crying in my cornflakes.
    Like others, I am curious which configurations will offer it. I was set on the 6ft bed with a manual, and the only option was the Sport AC (I "only" had to go two states over to find one), but I would have loved a DCLB manual.
    Henry1jg and doublethebass like this.
  17. May 9, 2023 at 5:22 PM
    #117
    Sinister184
    I’m in the south east. Mine were buy quotes as well not trade.
  18. May 9, 2023 at 5:52 PM
    #118
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Odd. How long ago was this? I am getting the sense that the market is softening a bit, but the $10k under MSRP offer had me spitting the proverbial coffee out of my nose. I was expecting to be at least a little tempted to do it. I wonder if I can offer it in different markets, or if they have the VIN locked in their quoting system now..Michigan is pretty domestic dominated but the Toyota dealers here still don’t seem to have any problems moving their inventory, nor pre-selling most, if not all, their MT’s while in transit.
  19. May 9, 2023 at 6:22 PM
    #119
    Sinister184
    Just a few weeks go. I’ve checked a few times over the last month. Fist offer was good, second was less, third a few weeks ago was best. It fluctuates for the online buyers.
  20. May 11, 2023 at 8:06 AM
    #120
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    So all this bullshitting here for months from "insiders" proved that it was all a farce. Gotta get it from the horses' mouth.
