4th gen will come with manual
Discussion in '4th Gen. Tacomas (2024+)' started by suprafastcelica, May 2, 2023.
  1. May 18, 2023 at 7:36 PM
    #141
    GBR
    GBR Well-Known Member
    19 TRD OR
    I can only think of one hybrid manual ever sold in North America (Honda Insight). It would be awesome if Toyota paired the hybrid power plant with the 6MT, but it's just not even remotely realistic.
    It would be a large engineering expenditure and split manufacturing on an already niche model. I think Toyota typically put out around 12,500 manual 3rd gens per year. I mean c'mon, maybe just be happy a manual exists at all in the 4th gen?
    Also it's a turbo, you'll undoubtedly be able to tune more HP stock and probably have aftermarket options for an upgraded turbo and fueling if necessary.
  2. May 18, 2023 at 7:40 PM
    #142
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Honda Insight and Honda CRZ.
  3. May 18, 2023 at 7:41 PM
    #143
    proudsource
    proudsource Active Member
    2023 OR 6MT IC
    they already had to detune the 2.4TT a little bit for the 6MT due to “crankshaft hammering” … no way it could handle the hybrid output
    Canadian Caber likes this.
  4. May 18, 2023 at 7:46 PM
    #144
    GBR
    19 TRD OR
    Interesting, do you have a source on the crankshaft hammering? Just haven't seen any info like that yet and would like to.
    oconnor, AdventureKid and Halibut like this.
  5. May 18, 2023 at 7:54 PM
    #145
    apowers
    apowers '23 TRDPro6MT Solar Octane
    TRD Sport 6MT has push button start. Yay!
  6. May 18, 2023 at 8:00 PM
    #146
    Halibut
    Halibut Well-Known Member
    Alaska
    18 OR SB MT
    Ugh why would we want this? Just read a post about a guy getting his truck broken into via the signal from the truck. I'm perfectly happy with a key
    Edit: I'm also perfectly happy they don't offer the Mt in the hybrid drive. I don't want the added complexity or weight.. I bet you can add quite a bit of power with a downpipe and a tune anyway
  7. May 18, 2023 at 8:15 PM
    #147
    radclerk1
    radclerk1 Well-Known Member
    Vic
    2017 Access Cab 2.7L Manual 4x4
    None
    Did I miss it, which models are coming with the Manual Trans? I’d love to have the two door prerunner model with 2wd here in FL.
  8. May 18, 2023 at 8:18 PM
    #148
    apowers
    The key also emits a signal when you unlock. I understand the risk, but I will take the convenience of a push button start.
    vtown likes this.
  9. May 18, 2023 at 8:26 PM
    #149
    ManInTheMaze
    ManInTheMaze Well-Known Member
    Mendo
    2003 and 2017
    Doesn't look like the prerunner will have MT. Based on the info available, the Xtra Cab will not get an MT, only double cabs. Not sure about long beds yet.
    AdventureKid likes this.
  10. May 18, 2023 at 8:51 PM
    #150
    proudsource
    2023 OR 6MT IC
    https://youtu.be/78mpK0RrQcM
    somewhere after 26 minutes in
  11. May 18, 2023 at 9:27 PM
    #151
    shakerhood
    Southern Ohio
    It sounds like 2 different tune Manuals, low output on the SR and the 270HP version on the Sport and Off Road.
  12. May 18, 2023 at 9:27 PM
    #152
    duckytw
    duckytw Well-Known Member
    They still kept the left - right steering wheel volume control :rofl:
    And the prop rod for the hood!
    I'd like to see if the limited full time 4WD can be paired with the manual.
    6MT has standard accumulator delete.
    Heads up display too
    Biggest for me is the power tailgate!
    MOC221_, Henry1jg and AdventureKid like this.
  13. May 18, 2023 at 9:33 PM
    #153
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    will be interesting to see if that SR 6MT can be paired with the Xtra Cab
    HV101, specter208, radclerk1 and 2 others like this.
  14. May 18, 2023 at 9:36 PM
    #154
    AdventureKid
    AdventureKid Let's Go Places
    Jake
    Oceanside, CA
    17' DCSB TRD OR 4x4 6MT
    Camper Shell
    28:50 He says, we do offer the 6MT in the ORP? Is he referring to the Off-Road Pro? TRD Pro? Off Road Premium?
  15. May 18, 2023 at 9:40 PM
    #155
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    great video, that one blue got cloth seats heated steering wheel and heated seats
    if what we see on the 3rd gen holds true for 4th gen, there should be a package that upgrade it to have softex ventilated seats
    shakerhood likes this.
  16. May 18, 2023 at 9:41 PM
    #156
    duckytw
    I heard that too. I think they mentioned ORP in a different point too earlier in the vid... I think it is Off Road / Pro. Seems to me the manual will be SR/Sport/OR/Pro?
  17. May 18, 2023 at 9:41 PM
    #157
    malatx
    off road premium
    it's probably just Off Road trim with Premium package
  18. May 18, 2023 at 10:03 PM
    #158
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    TysonBison and Henry1jg like this.
  19. May 19, 2023 at 6:18 PM
    #159
    54_96
    54_96 Well-Known Member
    I was on the fence about getting a 23' MT because I was 98.9999997% sure the MT would be a gonner. BUTTTTTTTTTTT after seeing the 24' and how butt ugly it is (at least at the moment), I think I'd rather take my chances with a 23' and probably save $10,000.
    vivid02 likes this.
  20. May 19, 2023 at 6:29 PM
    #160
    malatx
    I disagree, 4th gen MT with auto rev matching, no accumulator and increased torque can be a total blast to drive and worth that extra $10k
    GBR likes this.
