4th or 5th gear
Discussion in 'Towing' started by psmcn, Jul 10, 2012.
  1. Jul 10, 2012 at 6:07 PM
    psmcn
    psmcn [OP] Well-Known Member
    Paul
    Rockville Md
    I decided to read the owners manual about driving with a trailer and what gear to be in. I have been driving in D this year and I have had no hunting issues and the gas mileage is better. Upon reading the manual I found that it said that while towing you should dive in 4 not D for engine braking. It never mentions transmission issues as a reason to drive in 4 instead of D.. My truck and trailer brakes work very well and the 4.0 does not have enough compression to engine brake for me anyways.
    Just my observations. I will continue to drive in D and if it does start to hunt I will down shift.
    I think a clear idea of what hunting is is needed as well. Hunting is not your trans dropping into the passing gear while in drive and then back every once-in-a-while. Hunting is the trans going back and forth from gear to gear in rapid succession say 5-10 seconds apart. I have never had the Taco hunt I only give it a little help getting into a climbing gear either 4 or 3 before the trans does it for me.
  2. Jul 10, 2012 at 6:12 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    Driving hwy/straight flat roads should be fine in 5th......driving on back roads and that have hills and curves probably would want in 4th as it would "hunt" quite a bit
  3. Jul 10, 2012 at 6:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Leave it in "D" if its not hunting.
  4. Jul 12, 2012 at 7:28 AM
    Gunga
    Gunga Well-Known Member
    Glendale, AZ
    2008 TRD OffRoad DC 4x4
    I leave it in D mostly.
  5. Jul 12, 2012 at 10:21 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    This
  6. Jul 12, 2012 at 10:45 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    This
  7. Jul 25, 2012 at 6:46 PM
    gologit
    gologit Well-Known Member
    Bob
    In the redwoods.
    2011 4x4. Leer canopy Firestone airbags
    Nothing major or fancy. Just stuff to make it work better for me.
    Exactly right. I just brought a 17 foot Casita from Rice, Texas to my home in northern California. I ran I-40 most of the way.
    When you get into long pulls or even rolling hills you might kick the cruise control off and just "feel" for the sweet spot in each gear.
    I stayed in 5th most of the time and occasionally dropped to 4th on long up grades. No problems at all.
