4wd Actuator Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KCi238, Mar 4, 2017.
  1. Mar 4, 2017 at 8:02 AM
    KCi238
    KCi238 [OP] AKA K-Flo
    Hey guys,
    I'm new to this forum but I've been doing mechanical work for a while. I recently put together my first youtube tutorial on fixing the 4WD actuator on the Tacoma. Let know what you think about the video:
    https://www.youtube.com/watch?v=ZJESG91GbCQ
    I'm open to all constructive criticism, feedback and comments.
    Cheers,
    -Karl
    winkel, Jeff OB, TheMuffinMan and 5 others like this.
  2. Mar 4, 2017 at 8:14 AM
    Doublecross
    Doublecross Well-Known Member
    Robbie
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
    How did you refill it with fluid once you was done :thumbsup:
  3. Mar 4, 2017 at 8:14 AM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Nice job! Clear veiw.Welcome to Tacoma land roam with us learn from us like we learned from you!ps I use gas/oil gasket maker no wait time and made for it.
  4. Mar 4, 2017 at 8:19 AM
    KCi238
    Hi Doublecross, there's a drain and fill plug on the front differential. It's similar to the rear differential. I'll put together a video for that when I do the front differential fluid maintenance lol.
  5. Mar 4, 2017 at 8:20 AM
    KCi238
    I see, I will keep that in mind the next time! thanks!
  6. Mar 4, 2017 at 8:25 AM
    Doublecross
    Robbie
    New york
    Work in progress
    yes i know he wanted comments on video lol
  7. Mar 4, 2017 at 8:25 AM
    Pigpen
    Dan
    Northwest Montana
    Excellent how-to! Thank you for your contribution!
    @MTgirl sticky?
  8. Mar 4, 2017 at 9:56 AM
    11DBJR
    11DBJR Well-Known Member
    JR
    O'side, CA
    2011 4x4 Access Cab 6-speed manual
    I like that you accelerated the video of disassembly and reassembly as needed. Too many videos spend 20 minutes taking off one bolt with some kind of narrative that annoys me to no end! Nice video!
  9. Feb 4, 2019 at 12:51 PM
    McCoy104
    McCoy104 New Member
    Scott
    2012 TRD
  10. Aug 14, 2020 at 4:05 PM
    krn_taco90
    krn_taco90 Well-Known Member
    Jonathan
    2019 Super White Tacoma TRD pro
    RRW Rock sliders/Front pro grille lights
    DOES ANYBODY KNOW WHERE THE WASHER GOES INSIDE THE ACTUATOR I TOOK MINE APART AND THE GEAR FELL OFF AND A WASHER WAS THERE AND I PUT IT BACK ROGETHER AND WILL NOT WORK IT SAYS 4wd CANNOT ENGAGE PLEASE NEED GELO ASAP IN MY GARAGE RIGHT NOW NEED TO GO TO WORK!! :(
  11. Dec 7, 2024 at 12:40 PM
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    Just finished this repair today. Fortunately the actuator seemed to be the cause of the issue. I did crack open the original one and looked pretty clean inside. The gears did feel like they had some binding in them. I’ll connect a little battery to it later to see what was going on. I added some black gasket sealer to the new part and some hose clamps for breather tube.
