4wd actuator not actuating
Discussion in '1st Gen. Tacomas (1995-2004)' started by mike759, Jun 1, 2025.
  1. Jun 16, 2025 at 9:33 PM
    Red_03Taco
    Red_03Taco @ the Taco Shop
    Jerad
    Yavapai County, AZ
    2003 Tacoma Xtra Cab 4WD
    Eaton E-locker (rear), Alcan Leafs, Toytec 2.0s (rear), Icon 2.5s (front)
    Bummer. Now you did check the one on the Tcase right? Not the one on the front diff?
    If so, then yea, your A.D.D. actuator is the next thing you'll want to check. The motor could just be bound up internally, especially if you hadn't been using 4WD often.
  2. Jun 17, 2025 at 7:55 AM
    mike759
    mike759 [OP] Well-Known Member
    Colorado
    2002 Xtra cab TRD off-road
    2.5" lift, JBA UCA, OME rear leafs, 33s...
    That was my line of thinking since it did look like some water got in there and I haven’t used 4wd since like February. I have a spare motor actuator assembly I’m going to pick bits off of later and see what makes something happen. While messing with the transfer case yesterday it seems I have spun it into 4wd by hand, which would trigger that position sensor right? Still no light at all though. Had to drive to work this morning with the case in 4hi lol
  3. Jun 17, 2025 at 8:13 AM
    Red_03Taco
    Jerad
    Yavapai County, AZ
    So the position sensor on the tcase just tells the truck once the tcase has engaged 4wd (doesn't do anything for the light), then and only then will the ADD actuator engage and now the truck is actually in 4WD. Thats when the position indicator switch on the front diff can detect that 4WD is active and it signals the 4WD ECU to illuminate the light on the dash
  4. Jun 17, 2025 at 9:56 AM
    mike759
    Colorado
    Does the position switch on the diff trigger the blinking light? I guess I’ll be checking that later as well. Does it work the same as the tcase one?
  5. Jun 17, 2025 at 10:44 AM
    Red_03Taco
    Jerad
    Yavapai County, AZ
    I believe just the action of engaging 4wd should trigger the blinking light (so technically that should be the 4WD ECU triggering it).
    Yes, that front diff switch is identical (same part # and all) as the tcase one.
  6. Jun 17, 2025 at 11:03 AM
    mike759
    Colorado
    if that’s the case I guess I need to assess the 4wd ecu as well. I don’t get any kind of light when the button is pressed
  7. Jun 17, 2025 at 11:17 AM
    Red_03Taco
    Jerad
    Yavapai County, AZ
    Yea that would seem it could only be the button itself, the wiring from the button to the 4WD ECU, or the 4WD ECU, preventing the light from flashing
  8. Jun 17, 2025 at 4:32 PM
    mike759
    Colorado
    Pulled the 4wd ecu and don’t see any signs of failure (burns or damaged solders). Additionally, I’m no electrician but is it weird that I get a constant 12 volts at the 4wd button but 0 when it is pressed? To clarify, 12 volts unpressed, 0 volts when pressed. Everything else seems to have continuity where it should. I’m further stumped.
  9. Jun 17, 2025 at 6:24 PM
    Red_03Taco
    Jerad
    Yavapai County, AZ
    I wish I were more of an electrician myself and could help you out. Maybe those smarter than I can answer if thats normal or not
    @Dm93
    @Strictlytoyz
    Dm93 and Strictlytoyz like this.
  10. Jun 17, 2025 at 6:46 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    First things first, have you checked for continuity at the 2-4 selector switch yet?
    Red_03Taco likes this.
  11. Jun 17, 2025 at 7:04 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I really don't know alot about the 1st gen 4wd system, if this was a 2nd gen I could tell you exactly what to check.
    Being we have no light or any action of any kind the first thing I would check is the 4wd fuse, if that's good then check power and ground at the 4wd ECU which looks to live somewhere behind the center console.
    The Rear Diff Lock has a separate control ECU on 1st gens (Rear Diff Lock ECU) behind the left kick panel.
    Red_03Taco[QUOTED] likes this.
  12. Jun 17, 2025 at 8:55 PM
    mike759
    Colorado
    I just checked the voltage when the switch is pressed. Would I just check continuity at the connector just below the switch?
    The 4wd fuse looks good so I guess the issue may lie at the 4wd ecu. It sounds like I just pulled the diff lock ecu to check for damage. The 4wd ecu is the green unit behind the cigarette lighter in the dash I assume? What would I be looking for if I pulled it out?
  13. Jun 17, 2025 at 9:30 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Don't know what color it is but it should have a single 26 pin connector.
    Any obvious corrosion or damage, should have Power on Pin 12 (Black/Yellow) and Ground on Pin 25 (White/Black).
    Pin 4 (Red) is the selector switch input, it should be grounded when the switch is depressed.
  14. Jun 17, 2025 at 9:30 PM
    Red_03Taco
    Jerad
    Yavapai County, AZ
    If you look at the bottom of the 2nd picture in this post and the top of the 3rd picture, you'll see how to check continuity for the limit switch
  15. Jun 17, 2025 at 9:40 PM
    #35
    mike759
    Colorado
    Ok sweet I’ll give that a go tomorrow.
    I see now the switch can be checked all the way at the diff I had been assuming there was a lot in between it.
  16. Jul 15, 2025 at 8:40 PM
    #36
    mike759
    Colorado
    Still messing around
    I've been messing around with the 4wd unit a bit and not getting any signal at any of these pins with the switch on or off. I brought it to a shop to confirm and they aren't getting any power either. They also said they've never seen one of these computers fail, and it is a Toyota 4x4 specialty shop. I have a new (used) ecu on the way, just odd how rare of an issue this seems to be.
  17. Jul 15, 2025 at 9:00 PM
    #37
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No power to Pin 12? That's the main power feed to the module, of course it won't work if it doesn't have power to it.
    Have you checked the 4wd fuse?
  18. Jul 15, 2025 at 9:25 PM
    #38
    mike759
    Colorado
    fuse is good, even tried a new one anyway. Is there a way to check if it’s getting power at the fuse?
  19. Jul 15, 2025 at 9:27 PM
    #39
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Test light.
  20. Jul 15, 2025 at 9:48 PM
    #40
    mike759
    Colorado
    Can I use a multimeter to see if it gets 12 volts? If so, which side is positive and negative?
