4WD Actuator Troubleshooting (Transfer Case and ADD)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigWhiteTRD, Nov 18, 2018.
  1. Sep 1, 2024 at 5:45 AM
    TDHofstetter
    TDHofstetter Member
    Tim
    Bradford, VT
    Color-matched Leer cap
    No need to spoof the motor with a resistor, which would require a very large power resistor and generate a lot of heat. Just leave the motor lying somewhere and keep it connected. It'll hurt nothing if it runs for a little while every time you shift your TC.
  2. Sep 1, 2024 at 6:03 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Not a fan of solutions like that. The resistor generates no heat due to how large it is and how little the ECU needs it to be energized. This is the same resistor the 2lo mod uses and nobody has had an issue with it, under the same purposes.
    the ECU is essentially checking the motor is there at startup and then it energizes it briefly during shifting until the limit switches are where they need to be. Since the limit switches are now spoofed also, the ECU is basically satisfied immediately and doesn’t energize the resistor for more than a split second. In other words, it’s very rare that the ECU actually does anything with the resistor, but it needs to be there to get rid of the motor. I just don’t like options like leaving the motor connected and zip tied somewhere, not as clean.
