4WD and Radio Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KaptainKrieg, Jan 19, 2010.
  1. Jan 19, 2010 at 7:05 PM
    KaptainKrieg
    KaptainKrieg [OP] Active Member
    Taco V6 4WD
    I am writing to see if anyone else has had the same issues I have.
    1.Once the vehicle is engaged in 4hi, the differential axle screws up and causes the vehicle to spin out of control even at low speed when turning corners. Vehicle wont switch in to 4 low.
    2. The radio. I've had the radio replaced once already and the second one is on the fritz. There are major electrical problems with this truck. Turn the lights on and your radio turns on, turn a corner and your radio turns off. I think Toyota has issued a band aid fix, telling owners that the problem is a defective radio, when the electrical system is to blame.
    I think its time for people who have been ripped off by Toyota to band together before someone gets killed.
  2. Jan 19, 2010 at 7:08 PM
    KaptainKrieg
    Taco V6 4WD
    <----2009 Toyota Tacoma Access Cab w/4WD
  3. Jan 19, 2010 at 7:19 PM
    KaptainKrieg
    Taco V6 4WD
    My best guess is that the rear axle is locking up and the wheels are trying to spin at the same speed. In any case, the back of the truck slides like a drift racer going 10mph while in 4WD while taking a corner.
  4. Jan 19, 2010 at 7:22 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    You aren't by any chance driving in 4WD on dry pavement are you?
  5. Jan 19, 2010 at 7:22 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel),upper grillcraft, OEM color matched front grill color,OEM color matched-rear bumper, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,Timcha shackle receiver,bulaculla trailer relocate harness,ICON 2.5 Coilovers, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.morningstar PWM 30 charge controller. Pro comp wheels - BFG 265/75/16 AT's. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Is is KaptainKreig or Captain Morgan? Your post makes NO sense dude ?
  6. Jan 19, 2010 at 7:23 PM
    KaptainKrieg
    Taco V6 4WD
    Yes, my wife's got to drive this thing to work, and I need to get some answers sooner rather than later.
  7. Jan 19, 2010 at 7:25 PM
    KaptainKrieg
    Taco V6 4WD
    What doesn't make sense? The wheels don't spin at different rates when going around a corner in 4WD, and radio sucks.
  8. Jan 19, 2010 at 7:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep........i am ( ) <----- that close.
  9. Jan 19, 2010 at 7:28 PM
    KaptainKrieg
    Taco V6 4WD
    ok sorry, I'm not sure if its my multiple posts that have got you upset or their content, but I want to play by the rules. I don't suppose you have anything helpful to tell me?
  10. Jan 19, 2010 at 7:33 PM
    KaptainKrieg
    Taco V6 4WD
    Thanks, I'm new to posting on forums. I'm definitely going to try to utilize my warranty, but my dealership hasn't been the most understanding. It was like pulling teeth just to get the radio fixed. Seems like a bad ass truck when it works correctly. Apologies to all for the multiple posts.
  11. Jan 19, 2010 at 7:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    and sometimes....may need to try a different stealership if you have any close to ya.
  12. Jan 19, 2010 at 7:36 PM
    KaptainKrieg
    Taco V6 4WD
    I don't understand why a truck with less than 3000 miles could have so many issues. Im glad I've got a manual. I've read about situations where the automatic rev's out of control and downshifts at high speed causing loss of control. Doesn't seem like the Toyota company of 20 years ago.
  13. Jan 19, 2010 at 7:38 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the thing you gotta remember............there are gonna be lemons every once in a while....i dont care who makes that particular vehicle. and certain probs that are easy enough to fix...just aggravating.
  14. Jan 19, 2010 at 7:38 PM
    KaptainKrieg
    Taco V6 4WD
    Seems like the dealerships in the Gay Area are out to gouge. Perhaps I'll take it to a dealership in the valley.
  15. Jan 19, 2010 at 7:42 PM
    KaptainKrieg
    Taco V6 4WD
    Agreed, but take the radio problem for instance. If you type in a search on google about radio problems in the Tacoma, you'll get scores upon scores of posts on various forums, yet Toyota doesn't acknowlege that anything is going on. After pressing the mechanic at my dealership, he finally admitted that theyve seen dozens of these problems and Toyota has been mulling over a TSB. That was 5 months ago. I like the rigs that you guys have, and admire all the prowess with modding and so forth. My beef is with the jerks with the pie charts who think they can make more money by pretending these problems aren't widespread.
  16. Jan 19, 2010 at 7:47 PM
    KaptainKrieg
    Taco V6 4WD
    Im not sure which gear it was. I think from 3rd to 2nd, it downshifts prematurely in some trucks causing sudden deceleration. Don't quote me on that, do your own search. Thats mybest recollection.
  17. Jan 19, 2010 at 7:57 PM
    KaptainKrieg
    Taco V6 4WD
    Roger that on the documentation. Just so you dont think I'm totally full of it, heres a link to one of the posts on the downshifting issue.
    http://townhall-talk.edmunds.com/direct/view/.f0de869/235
  18. Jan 19, 2010 at 8:00 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I don't know anything about the 4X4's but could this be a locker issue, do the 4by's have lockers? :notsure:
  19. Jan 19, 2010 at 8:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i understand....and i agree with ya.
  20. Jan 19, 2010 at 8:01 PM
    KaptainKrieg
    Taco V6 4WD
