4WD and starting 08
Discussion in '2nd Gen. Tacomas (2005-2015)' started by buckybev, Oct 26, 2011.
  1. Oct 26, 2011 at 5:52 AM
    buckybev
    buckybev [OP] New Member
    Chuck
    Chicago
    08 Tacoma 6cl
    hey guys got two problems hope I can get help with. truck almost stops dead with 4w on and making a sharp turn.Have to really give it the gas to keep rolling. Going down the road seems fine but turning a corner or into a parking space she just about wont move ? And do all tacomas race to 1500 on starting seems to really take off. Scares me to think what that does in zero weather to the engine.
  2. Oct 26, 2011 at 5:55 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    Yes, the engine will rev to a higher RPM as part of the emissions and starting procedure.
    are you using your 4wd on dry pavement? if so, it will grab each tire and cause premature ware to your driveline parts. if you can drive straight with no issues, don't engage on dry ground, only wet, off road and snow where the front tires are allowed to slip in a turn.
  3. Oct 26, 2011 at 5:56 AM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    If you are using 4WD on dry pavement (especially if you are making turns, let alone sharp turns), you should stop! Use 4WD only in slippery conditions such as mud, snow, or sand, and only exercise it if you must on a straight stretch.
    And welcome from an Illinois expat. : )
  4. Oct 26, 2011 at 5:59 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    X2
    Never use 4WD on dry pavement, That stopping you feel is binding in the driveline and will damage it if you do it to many times.
  5. Oct 26, 2011 at 6:07 AM
    buckybev
    Chuck
    Chicago
    08 Tacoma 6cl
    wow thanks guys . Just got rid of my Jeep which i did drive in 4w for the Tacoma. So far still learning ....
  6. Oct 26, 2011 at 6:09 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    You and me both...this is my first 4WD. I actually bought it mostly because of my Christmas trips to see family in Illinois...I was tired of sliding into ditches. :D
  7. Oct 26, 2011 at 6:14 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Even in snowy parking lots, I always disengaged my 4WD when pulling into a tight spot to park my tacoma. It is the same in my tundra.
