4wd conversion - Donor Truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoluke10, May 2, 2022.
  1. May 4, 2022 at 5:56 PM
    #41
    Kwikvette
    Fresno County
    4 run, 2 don't
    Geo's were more reliable, so technically they're worth more :burp:
    MalinoisDad[QUOTED] likes this.
  2. May 4, 2022 at 6:46 PM
    #42
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Delivered to California?? Fuel might be a tad expensive!!
    Taco critter and MalinoisDad like this.
  3. May 5, 2022 at 7:03 AM
    #43
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    In here late but, I did mine for $2100.
    That was with swapping to 4.56 gears, lunchbox locker upfront, truetrac in the rear, and spending more on the spindle/hub setup than I should have.
    Definitely possible to do these swaps for under $1500, just take your time sourcing parts. I didn't get a single part local besides my driveshaft.
    Area51Runner likes this.
  4. May 5, 2022 at 10:36 AM
    #44
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I'm down to help tackle it. I have not done the manual swap, but I have done the 4wd swap.
    I started sourcing parts, and then as I got them I made decisions on what needed to be improved or rehabbed while I sourced the other parts.
    Things I mean by improved and rehabbed:
    - I bought new spindles for the swap. That way I could gusset the spindles and replace the wheel bearings and have them ready to go when I did the swap
    - I did a shift kit in the auto trans while it was waiting to go in. (If you manual swap, I would definately recommend a new clutch, because why not? The trans is already out of the truck)
    - I rebuilt the CVs I had for the swap, fresh grease and high angle boots inner and outer.
    - Unless your LBJs are new, I would suggest replacing those while you're in there
    Other things to think about are:
    - Drive/pass seals on diff (would be done if you regear and lock)
    - Input/output seals on t case
    - Carrier bearing
    - U-joints on driveline
    I have since did a locker, in the front diff. It's expensive (especially with all the other costs of the swap at the same time) but if I had to do it all over again, I would have regeared (front diff and rear axle) and put the locker in the front all at the same time.
    If you have all the parts, it really isn't that bad to do. All the "front end" stuff... diff, CVs, etc can be done seperately from the Trans/tcase/drivelines.
    I did the front end stuff with just me and one of my sons after work on a Friday, and then the trans/tcase/drivelines on Saturday and finished Sunday. Saturday I had some help from some heavy hitters for the trans etc, though.
  5. May 5, 2022 at 10:56 AM
    #45
    Bivouac
    It is not really the parts that drives up the cost.
    It is being able to pay for decent labor as I end up working so often for free or even spending money to help out follow Toyota Owners.
    I can respect budgeting the labor into the over all cost.
    MalinoisDad likes this.
  6. May 6, 2022 at 8:01 AM
    #46
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    and then just swap the parts?
    All bolt-on plug and play, right?
  7. May 6, 2022 at 8:08 AM
    #47
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I think you misunderstood.
    Buy a Land Cruiser, and you have a solid axle. That's it. No plug and play. The solid axle is under the Land Cruiser (like he did).
    It's kind of like the "Daily Driver mod" only different.
    Kwikvette likes this.
  8. May 6, 2022 at 8:10 AM
    #48
    jbrandt
    Justin
    That's the joke... ;)
    There's a thread of a guy wanting to use all 80 series parts because apparently that makes SAS idiot proof.
  9. May 6, 2022 at 8:12 AM
    #49
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    LMAO... Although not idiot proof. I would certainly like to get my hands on a full float/disc 80 series rear axle for when I go LT.
  10. May 6, 2022 at 8:13 AM
    #50
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I converted my 1998 PreRunner 4cyl. It took me a year of collecting parts piecemeal, and two weekends to assemble it. It only cost about… $500-$750 total after I sold my old steering knuckles and A340E transmission.
  11. May 6, 2022 at 8:16 AM
    #51
    Kwikvette
    Fresno County
    4 run, 2 don't
    You're a monster
  12. May 6, 2022 at 8:17 AM
    #52
    Kwikvette
    Fresno County
    4 run, 2 don't
    If I can get my hands on a front setup with factory locking diff, you're welcome to have mine :burp:
    Though I should really just focus on the rear first.
  13. May 6, 2022 at 8:18 AM
    #53
    jbrandt
    Justin
    yeah, that'd be sweet
  14. May 6, 2022 at 8:19 AM
    #54
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    They are not real easy to find. And the ones I have found have been stupidly over priced. (and not close enough to go get) lol
  15. May 6, 2022 at 8:21 AM
    #55
    jbrandt
    Justin
    I know
  16. May 6, 2022 at 9:06 AM
    #56
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just saw this post :rofl:
    Knowing you, there's a chance the rest of us would show up for a mod party and you'd be texting me from the hospital again saying you can't make it :luvya:
  17. May 6, 2022 at 9:10 AM
    #57
    jbrandt
    Justin
    I'm hoping my time in hospitals is over for a while.
    Kwikvette[QUOTED] likes this.
  18. May 6, 2022 at 10:17 AM
    #58
    choopes
    choopes Well-Known Member
    Troy, Al.
    2004 reg cab
    Stock
    Buying a donor truck is expensive, but if you do, try to find local. Those transporting cost are a monster!
  19. May 6, 2022 at 10:18 AM
    #59
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Mod Party?
    :mudding::rockband::mudding:
  20. May 6, 2022 at 2:34 PM
    #60
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Wish we were still dealing in 2017 prices... lol.
    BartMaster1234[QUOTED] and Wulf like this.
