4WD Conversion LA or Orange County
Discussion in 'Southern California' started by Est3ro, Feb 6, 2019.
  1. Feb 6, 2019 at 10:49 PM
    Est3ro
    Est3ro [OP] Member
    Louie
    2000 Black Tacoma
    Just a few things here and there
    Just curious if anyone locally has done this Conversion. I’m in Long Beach
  2. Feb 7, 2019 at 1:10 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. Feb 7, 2019 at 1:48 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I’m in the SF Bay Area and did this conversion. What do you want to know?
  4. Feb 8, 2019 at 6:35 PM
    Est3ro
    Est3ro [OP] Member
    Louie
    2000 Black Tacoma
    Sorry guys should of been a little more specific. 2000 AT V6 3.4L. And now that I think about it. Wondering if this is even possible with the current lift I’m running. I have the Total Chaos LT. I know it says it’s for the prerunner and 4wd. I know for sure I’d need extended cv’s.
  5. Feb 8, 2019 at 6:43 PM
    Est3ro
    Est3ro [OP] Member
    Louie
    2000 Black Tacoma
    I want to keep it AT. And something simple, so manual hubs. I’d like to do it in two parts if possible. Transmission and transfer case and keep 2wd for awhile. And then do the rest. It’s my DD and doubt a project like this would be done over a weekend.
  6. Feb 8, 2019 at 9:29 PM
    UnderFire
    UnderFire Well-Known Member
    It's easy, just keep it simple and use the mechanical parts. Manual hubs, Non-ADD stub shaft, J shift T-case. If you can swap out a transmission, you're good.
  7. Feb 8, 2019 at 9:46 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You can definitely have it done in a weekend. It’s that easy. Manual hubs and a j-shift transfer case setup is 100% bolt on. Even then, if you want to run ADD it’s only minimal wiring and/or running vacuum lines.
  8. Feb 8, 2019 at 10:26 PM
    Est3ro
    Est3ro [OP] Member
    Louie
    2000 Black Tacoma
  9. Feb 8, 2019 at 10:27 PM
    Est3ro
    Est3ro [OP] Member
    Louie
    2000 Black Tacoma
    Sorry guys for posting in fragments. Kinda hard while at work
  10. Feb 8, 2019 at 10:28 PM
    Est3ro
    Est3ro [OP] Member
    Louie
    2000 Black Tacoma
    Was also wondering about the spindle. Can I use my 2wd one or do I have to get a 4wd spindle?
  11. Feb 8, 2019 at 10:29 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I wouldn’t advise running the 4WD transmission in 2WD since you’ll get grinding if you don’t get the correct length rear driveline off the bat. I drove my truck in 4HI without a rear driveline essentially making me the world’s only FWD Tacoma for a week while I got the rear driveline shortened.
    I really wouldn’t advise doing it in two parts. I would get it all done at once.
    El_Rocinante likes this.
  12. Feb 8, 2019 at 10:30 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You can, but you have to press out the wheel hubs and since it looks like time is your issue it’s easier to have steering knuckles ready to swap out.
  13. Feb 9, 2019 at 10:42 AM
    Est3ro
    Est3ro [OP] Member
    Louie
    2000 Black Tacoma
    I think for this project I will be able to get a car, so that won’t be a problem. Just figured since besides doing the brakes and radiator. This will be the biggest job I’ve done. BecUse of that didn’t think I’d be able to have it done over a weekend. A friend of mine is good friend with someone that has a shop so hopefully he can let us borrow some stuff of even let us do it there. I would think he could press out the hubs
    Also read about a few people buying transmission and then rebuilding them? Besides that wondering what other things I can rebuild/upgrade while doing this project. One that I heard was the bearings. Oh and I can’t remember what gears I have in the back I believe 4.10’s?
    But I want to eventually change to a 4.88 due to 33’s and the try and extra weight. What problems would I encounter with the front gears? Heard they have to match or be close or else they can get blown out or something along those lines.
  14. Feb 9, 2019 at 11:09 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Usually you don’t meed a rebuild on the auto transmissions if they’re solid and shift fine. They’re not like American transmissions, AISIN ones are plenty strong.
  15. Feb 9, 2019 at 11:14 AM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    If you have a lt kit you won't find axles for manual hubs or atleast I don't think you will
    SafetyDang likes this.
  16. Apr 23, 2019 at 9:15 PM
    mjhenks
    mjhenks Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    I just finished mine. I am in OC. PM me.
  17. Apr 24, 2019 at 7:17 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    I took a number of months to convert mine, so it can be done in stages...
    1st stage - Transmission, transfer case, rear driveshaft
    2nd stage - front diff and drivetrain (except front driveshaft)
    3rd stage - front driveshaft
    @SafetyDang is local to you (Anaheim) and has extensively 'forum-documented' his conversion.
  18. Apr 24, 2019 at 11:54 PM
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
  19. May 12, 2019 at 11:08 AM
    Lfaub03
    Lfaub03 4wd wannabe
    Logan
    Flagstaff, AZ
    2003 Prerunner TRD
    4wd conversion
    I’ve done the conversion, located in San Diego but got a lot of my parts from Arizona
  20. May 12, 2019 at 7:34 PM
    SafetyDang
    Dang
    Anaheim, CA
    If you have LT and want Manual hubs good luck. You might as well go ADD. I've talked to TLT was the only one that ran Manual Hub Tacoma Outters and Tundra Inner Shafts. They said it isn't worth it and to just go with ADD. I'm in LB and Anaheim lets grab a drink.
