4wd conversion. Need help please.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Des0911, Feb 19, 2018.
  1. Feb 19, 2018 at 4:19 PM
    Des0911
    Des0911 [OP] Well-Known Member
    Eric
    Baldwin Park
    2002 tacoma 4wd prerunner
    So I'm in the middle of my 4wd Convertion but my t case will not close up to my adapter. I believe it is the input shaft on my t case that is not allowing it to mate to the extension housing properly. Is there something I could do about the input shaft. Read some where it was for a manual trans and that's why it won't mate. Can I just replace input.
  2. Feb 19, 2018 at 4:20 PM
    Des0911
    Eric
    Baldwin Park
    Here is a pic
  3. Feb 19, 2018 at 4:23 PM
    tony2018
    tony2018 Well-Known Member
    wheres the housing?
  4. Feb 19, 2018 at 4:26 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    What kind of engine and transmission did the transfer case come off of? v6 transfer case is top shift and inline 4 transfer case is forward shift and has an extra intermediate housing to allow for the length difference of engines.
  5. Feb 19, 2018 at 4:32 PM
    Des0911
    Eric
    Baldwin Park
  6. Feb 19, 2018 at 4:33 PM
    Des0911
    Eric
    Baldwin Park
    The tcasr came off a v6 from what I was told. Here I'm my trans
  7. Feb 19, 2018 at 4:35 PM
    tony2018
    test fit the spline of the tc to the tranny?
  8. Feb 19, 2018 at 4:36 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Are you sure that there isn’t a dowel pin in both the transfer case and the transmission? There a couple pins that align the two and there’s a chance you accidentally have it one both halves. I feel like this isn’t making sense as I type it. But the alignment pins are only supposed to be either in the transfer case or in the transmission. When I did my conversion, the transmission had the pin and the transfer case both had the pins. It kept them from completely coming together. There was about a 1/2” gap. Took awhile before I realized what it was.
  9. Feb 19, 2018 at 4:44 PM
    Des0911
    Eric
    Baldwin Park
    This is exactly what is happening to mine. I have a half inch gap. So where are those pins at ?
  10. Feb 19, 2018 at 4:46 PM
    jowybyo
    Joe
    Baltimore, MD
    Along the mating flange where the bolts are. There’s a couple holes with short 3/8” dowel pins that help align the TC to the trans. Just make sure they are only in either the TC or the trans.
  11. Feb 19, 2018 at 4:51 PM
    Des0911
    Eric
    Baldwin Park
    I believe it is only on the adapter. Right?
  12. Feb 19, 2018 at 4:57 PM
    Des0911
    Eric
    Baldwin Park
    This is as far as it will go in
  13. Feb 19, 2018 at 4:59 PM
    tony2018
    remove tc and adapter from tranny, try to mount adapter into tc?
  14. Feb 19, 2018 at 5:02 PM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Right now it looks like its sitting on the shifter rods. Have you tried to put the shifter in 2wd, or another position to see if that helps? Also try turning the rear tcase driveshaft flange to see if wiggling will help seat further.
    Also like previously stated, try test fitting the tcase directly to the trans without the adapter housing.
  15. Feb 19, 2018 at 5:10 PM
    Des0911
    Eric
    Baldwin Park
    It still will not seat properly. Could it be that my t case came out of a manual trans and that it's diffrent?d if so do I need a new one or can I swap something out
  16. Feb 19, 2018 at 5:17 PM
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Ok so tcase adapter fits to trans. Check.
    Tcase fits to the tcase adapter. Check.
    Try just sliding on the tcase without the adapter to verify it will engage to the output splines from the transmission. If it wont, itll confirm your tcase has the wrong spline count.
  17. Feb 19, 2018 at 5:20 PM
    Des0911
    Eric
    Baldwin Park
    It's spines In no problem. Buts the output shaft hits the back of the Input shaft. It will not go in any further.
  18. Feb 19, 2018 at 5:36 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You used a t-case off a manual trams? That sounds like why it isn't fitting. Output/input shafts may be different lengths.
    Someone correct me if I'm wrong.
    Running Board Man likes this.
  19. Feb 19, 2018 at 5:37 PM
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Yep, I agree now. Since the splines matching up but the length is still too much then its a missed match manual/auto trans combo.
  20. Feb 19, 2018 at 5:41 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    As far as I know you can't use a v6 transfer case with a I4 transmission or a manual tranny transfer case with an automatic tranny transfer case.
