4WD conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by SargeSlapnuts, Dec 8, 2011.
  1. Dec 8, 2011 at 10:32 AM
    SargeSlapnuts
    SargeSlapnuts [OP] SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
    Well i am going to pick up my transmission and transfer case here shortly. i am converting my 2004 tacoma prerunner over to 4wd. i made sure to get an automatic transmission w/ manual transfer case and the trans computer to go along with it and am well aware that im gona have to shorten my rear drive shaft. i still have a few questions though.
    1. Will i be able to use auto locking hubs or can i use manual locking hubs and still throw no check engine lights.
    2. Will the final drive of this transmission be any different than my 2wd auto trans? i have look around and am struggling finding any good resources.
    3. I would like to install a powertrax no-slip in the front axle when i re-gear it to 4.56 gears to match the rear. is this a bad idea to lock the front i.e. will it cause any other parts to become a problem for breakage.
    4. will i need a different trans/transfer crossmember to make this build work?
    anyone who can answer or point me in the right direction would be much appreciated!
  2. Dec 8, 2011 at 10:54 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    1) You'll need a kit like this to convert to manual hubs: http://www.offroadsolutions.com/manual_hub_conversion.html
    2) No idea. I still firmly believe the automatic transmission is the downfall of modern society.
    3) I would only recommend a selectable locker for the front. Front Locker + IFS = Easy to break CV's
    4) Don't think so. Should be the same. IIRC the transmission mount (isolator) is the same too.
  3. Dec 8, 2011 at 11:07 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  4. Dec 8, 2011 at 11:09 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Damnit Ben. My name is Jason not Jerry. Don't confuse me with JLee. :)
  5. Dec 8, 2011 at 11:11 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I...............uh...............saw the ............uh................ FML.
    :eek:
  6. Dec 8, 2011 at 11:12 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    :eek:
  7. Dec 8, 2011 at 2:25 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I got $20 that say's he'll blame his phone.
  8. Dec 8, 2011 at 2:54 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Don't listen to these fools. :p
    Your going to only throw a cel if you don't get a new speed sensor if the transfer case doesn't have one, or if you don't plug all the tranny plugs back in, you don't need a new computer.
    You sure can put manuals up front all you need is a manual front diff, the axles, hubs and spindles it will all bolt right in and not throw any problems.
    put a selectable up front.
    and yes you need a new crossmember tranny mount thing, the prerunner one is different.
  9. Dec 8, 2011 at 2:55 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    prerunner vs 4wd speed sensor
  10. Dec 8, 2011 at 2:56 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    ANd it goes here on the t case
  11. Dec 8, 2011 at 2:56 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Nope, work comp. And I saw that ID............;)
  12. Dec 8, 2011 at 2:59 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    this is a pain in the ass
  13. Dec 8, 2011 at 3:11 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I just looked at the FSM and the transmission xmember looks identical. :notsure:
    The only thing that looks different is the mount to the transmission. I won't swear to it either way.
  14. Dec 8, 2011 at 3:52 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Hope t works out for you but it sounds like a nightmare conversion.
  15. Dec 8, 2011 at 3:55 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    Why? A ton of people have done it with minimal problems :confused: TTORA is full of these conversions
  16. Dec 8, 2011 at 4:03 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    repost.
  17. Dec 8, 2011 at 5:59 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Yeah you can unbolt it and they are the same most people just swap em around as a unit, but if you find the mount it should work
