4wd conversion
Discussion in '4 Cylinder' started by Brian422, Jul 9, 2019.
  1. Jul 11, 2019 at 9:48 AM
    #41
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I listed everything in this post:
    You need to pull the transmission. Disassemble and swap in these parts. A good transmission shop should be able to do this no problem. If you bring them the transmission (so they don't have to remove it from the truck), it shouldn't cost a lot. But expect $200-300 cause it is a decent amount of work. The output shaft is the first thing that goes in the transmission, meaning it's the last thing out. So the whole thing needs to be taken apart to swap the shaft. I've seen some ppl swap it themselves, but for the amount I paid, it wasn't worth it to DIY.
    Brian422[QUOTED][OP] likes this.
  2. Jul 15, 2019 at 7:57 PM
    #42
    Derek Benson
    Derek Benson Member
    2007 silver Tacoma, 2.7, 5 speed, 4x4
    4x4 since 8/17
    http://mississippi-mud.com/thread-20326.html?highlight=4x4+conversion
    Just thought I'd add the link to my 4x4 swap from 2 years ago. It's on another site. I never got around to doing a write up on here:rolleyes: http://www.car-part.com/ was my best resource for larger parts. I got my wheel bearings pre-pressed from this guy http://www.marionbumper2bumper.com/ The guys at rocksolidtoys have a conversion transmission crossmember out now so that eliminates the need for fabricating your own crossmember. Hope this helps. Whenever I did this swap, no one one the internet had done a conversion on a 2.7 that I could find.
    Brian422[OP] likes this.
  3. Jul 15, 2019 at 8:03 PM
    #43
    jowybyo
    Joe
    Baltimore, MD
    You didn’t find me. I did it 4 years ago now. Awesome work though.
  4. Jul 15, 2019 at 8:05 PM
    #44
    Derek Benson
    Derek Benson Member
    4x4 since 8/17
    @jowybyo Thanks! I remember reading your write up after I got mine done. I didn't realize it was from that long ago
  5. Jul 15, 2019 at 8:12 PM
    #45
    jowybyo
    Joe
    Baltimore, MD
    Yea I can’t believe it’s been that long either. I’ve put almost 100k miles on the truck since.
  6. Jul 16, 2019 at 6:30 AM
    #46
    Brian422
    Brian422 [OP] I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    So for the automatic 2.7 which trans would you use? I could try to reuse mine since it only has 100k on it but it might just be easier to find another trans.
  7. Jul 16, 2019 at 7:22 AM
    #47
    jowybyo
    Joe
    Baltimore, MD
    You can find a lot of transmissions with under 100k miles for a reasonable price and sell yours to recoup some of the cost. I only kept my transmission because it had less than 25k miles and one with that low mileage was well north of $1k
  8. Jul 16, 2019 at 7:27 AM
    #48
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    so which ones will work? I have a 4 speed now. will a 5peed 4x4 tras work? Also will trans from 04 down work as well?
    Thanks
  9. Jul 16, 2019 at 9:15 AM
    #49
    jowybyo
    Joe
    Baltimore, MD
    You need a 4 speed auto 4x4 transmission. The model code is A340F. The 5 speed auto is for the v6 and won’t work. The 5speed manual is...well stick shift. No, you need a transmission from a ‘05-‘15. Closer to your model year the better.
  10. Jul 16, 2019 at 10:11 AM
    #50
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Great! I cant wait to get started on this. Just gotta round up the money.
  11. Jul 16, 2019 at 2:49 PM
    #51
    Derek Benson
    Derek Benson Member
    4x4 since 8/17
    @Brian422 better listen to the others with questions about the automatics. I know nothing about them since mine is a 5 speed manual
  12. Jul 19, 2019 at 4:27 PM
    #52
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    The electrical connections on the 1st gen A340 are different than the 2nd Gen. If you went this route with your trans you'd basically be paying them to rebuild your trans, but without new parts; so pay for new parts and have a rebuilt transmission. This is exactly what I'm looking at doing for my R155 to A340 swap, buying a cheap A340E and converting to A340F with performance parts (turbocharged 2TR here). Or wait a few months and driving up to VA for a few days and we swap transmissions and some cash and I help you do the 4x4 swap, I've got experience:
    https://www.tacomaworld.com/threads/prerunner-to-4x4-conversion-guide.534480/
  13. Jul 19, 2019 at 4:38 PM
    #53
    05Taco4x4
    2TR-FE Enthusiast
    Ah just seen you asked a question on it, already found it haha
  14. Jul 19, 2019 at 5:07 PM
    #54
    jowybyo
    Joe
    Baltimore, MD
    Wait, you are doing a 5-speed manual to auto conversion? If so, please PM me. I'm trying to do the opposite. We could literally swap parts.
