4wd conversion
Discussion in 'Suspension' started by Rguerra23, Dec 21, 2019.
  1. Dec 21, 2019 at 2:58 PM
    Rguerra23
    Rguerra23 [OP] Well-Known Member
    Rudy
    2003 Tacoma TRD
    Total chaos control arms
    Need some helpful tips on 2wd to 4wd conversion. How much would it cost and what parts do I need.
  2. Dec 22, 2019 at 9:24 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Sell your truck and buy a 4x4... thats how much it will cost.
    Or, go to a junk yard, buy a 4x4 frame, t-case, front axle, transmission, any electronics and wire harnesses that go with it.
    Hamer95USA and NateMob like this.
  3. Dec 22, 2019 at 11:55 AM
    Rguerra23
    Rudy
    2003 Tacoma TRD
    I’m trying to do this for both my Tacoma and GMC Sierra. With the Sierra the guy I got it from converted it into a 2wd and left the front differential in tact and took out the t-case and just had a really big driveshaft going to the transmission.
  4. Dec 22, 2019 at 12:03 PM
    Rguerra23
    Rudy
    2003 Tacoma TRD
    I can take pictures soon and show y’all what I mean. I believe it won’t be too bad bc the Sierra was already a 4wd in the first place.
    Running Board Man likes this.
  5. Dec 22, 2019 at 12:20 PM
    Rguerra23
    Rudy
    2003 Tacoma TRD
    2003 for the Tacoma and 2004 for the Sierra.
  6. Dec 22, 2019 at 12:30 PM
    Rguerra23
    Rudy
    2003 Tacoma TRD
    why is that?
  7. Dec 22, 2019 at 3:26 PM
    Rguerra23
    Rudy
    2003 Tacoma TRD
    Bet
  8. Dec 22, 2019 at 3:31 PM
    Bishop84
    Bishop84 Well-Known Member
    The 03-04 uses an updated transmission without a cable but electronic controlled solenoid valve. So more harness, more connectors.
    Also 03-04 has electric throttle body, that part of harness is different as well.
    You can't even share with the 4runner because the 4runner had a gen change in 2003 rather than updating the 5vz platform.
