4WD Disengage "Knock"!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by punkassprettyboy, Jan 18, 2011.
  1. Jan 18, 2011 at 6:14 AM
    punkassprettyboy
    punkassprettyboy [OP] President
    Tommy
    North Jersey
    2010 sr5 v6 4.0 trd SPORT
    tints, led interior lights, debadged, security system w/ auto start, 2 800w 10" woofers, rain guards and tow package so far.....
    What the heck is this jarring knocking sound when i disengage the 4wd? :confused:
  2. Jan 18, 2011 at 6:15 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    that is normal
  3. Jan 18, 2011 at 6:18 AM
    punkassprettyboy
    Tommy
    North Jersey
    Ive never noticed this before the cold weather set in.
  4. Jan 18, 2011 at 6:19 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Take the pressure of the drive-line (if you don't already).
  5. Jan 18, 2011 at 6:32 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Normal
  6. Jan 18, 2011 at 7:36 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    This, do you still have your foot on the gas when you take it out? If so take your foot off the gas.
  7. Jan 18, 2011 at 7:40 AM
    Jeff3004x4
    Jeff3004x4 Well-Known Member
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    Mine does it, it seems normal to me, everything I have ever owned that was four wheel drive made a similar noise.
  8. Jan 18, 2011 at 11:17 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    If it is just one knock (I call it a 'thump') then okay...
    Running the front drive shaft, differential, ADD, axles, tires with engine torque is a major deal... so expect something when you go in or out of 4 wheel drive.
  9. Jan 18, 2011 at 11:21 AM
    Trachito
    Trachito Well-Known Member
    New Orleans
    mine doesn't do it anymore since i got a lift and bigger tires. odd.
  10. Jan 18, 2011 at 11:22 AM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    It won't make the noise if there is no tension in the drivetrain. Disengage while you are coasting on flat ground and it should be silent; maybe just a small "click."
  11. Jan 18, 2011 at 11:55 AM
    BritMike
    BritMike Well-Known Member
    NJ
    10 Black TRD OR
    Mine used to do the same but since I've been going in and out of 4wd a lot recently driving in the snow it's stopped doing it.
    As others have said, if it's a single clunk it's no problem.
  12. Jan 18, 2011 at 12:15 PM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    Let it coast for a sec before you engage or disengage. Clunk means be patient with it.
  13. Jan 18, 2011 at 2:20 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Yeah I usually switch to N first and the clunk does not happen
  14. Feb 21, 2011 at 2:05 AM
    punkassprettyboy
    Tommy
    North Jersey
    okay, havent posted anything on this site in a minute...went to the store w/ the gf earlier today and wanted to park on top of a snow mound...(gf screaming in my ear, but did it anyways)...LOVE 4WD TACOS!...so we left, and im backing off mount everest..lol..and disengage the 4wd low and ...."BANG"...wtf was that? someone help please!
  15. Feb 21, 2011 at 8:22 AM
    David K
    Umm??? Isn't it the same sound as when you first asked? Hasn't everyone told you it is normal and some ways to perhaps lessen the sound?
    Did you not first shift from L4 to H4 at a stop and in Neutral (the standard way), then go from H4 to H2 while moving?
