4WD Double Cab V-6 Automatics Gas Mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by David K, Sep 28, 2011.
2005+ Double Cab, V-6, 4WD: Average Mileage
Poll closed Oct 28, 2011.
  1. 22+ mpg
    9 vote(s)
    2.8%
  2. 21-22 mpg
    14 vote(s)
    4.3%
  3. 20-21 mpg
    34 vote(s)
    10.5%
  4. 19-20 mpg
    73 vote(s)
    22.5%
  5. 18-19 mpg
    58 vote(s)
    17.8%
  6. 17-18 mpg
    59 vote(s)
    18.2%
  7. 16-17 mpg
    44 vote(s)
    13.5%
  8. 15-16 mpg
    23 vote(s)
    7.1%
  9. 14-15 mpg
    6 vote(s)
    1.8%
  10. Under 14 mpg
    5 vote(s)
    1.5%
  1. Sep 28, 2011 at 4:54 PM
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Beacuse there is just so many variables on truck models (reg cab, access cab, double cab) and engines (I-4, V-6) and transmissions (manual, automatic) and traction (2WD, 4WD)... Here is a poll to see what one group of Tacomas gets in gas mileage... So only vote if you have a 2005 + Double Cab, 4WD, V-6, Automatic... apples to apples, so to speak! Daily driving average, like is calulated on Fuelly.com, not that one trip where you got amazing mileage. Be honest. I once got over 19 mpg... but my average is 16+ mpg. Lately I have been getting 14-15. I just had new plugs instaled, so we shall see if that gets better.
    1. 22+ mpg
    2. 21-22 mpg
    3. 20-21 mpg
    4. 19-20 mpg
    5. 18-19 mpg
    6. 17-18 mpg
    7. 16-17 mpg
    8. 15-16 mpg
    9. 14-15 mpg
    10. Under 14 mpg
  2. Sep 28, 2011 at 4:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    New plugs should have given a slight increase in MPG. me thinks the plugs werent gaped correcty?
  3. Sep 28, 2011 at 4:57 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    I am in the 16 range when you adjust for the speedo being slightly slower due to running 285 70 17 Duratracs and an RCD Lift.
  4. Sep 28, 2011 at 4:59 PM
    David K
    Re-boot
  5. Sep 28, 2011 at 5:02 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
  6. Sep 28, 2011 at 5:05 PM
    David K
    Yah, the tire/ speedo relationship is resposible for at least 1 mpg change... The stock tires on my truck was 265/70-16, and the speedometer read too fast (giving better mileage per gallon!).
    When I put on the 1" taller 265/75-16 Dynapros, my speedometer read balls-on accurate (per my GPS)... However, I also lost about 1 mpg on most of my checks following the new tire purchase... BUT, that is the TRUE mileage, not the phoney Toyota extra mileage... right?
  7. Sep 28, 2011 at 5:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The speedo tells your speed. While it may have an error, the ODO is rather accurate.
  8. Sep 28, 2011 at 5:26 PM
    TacoDawgfan
    Georgia
    How do we know this for sure? I do know that with my last truck my drive to work was exactly 11 miles. Now I haven't remembered to check with the Taco, but the other day I did notice while watching my odometer since I was anticipating my best mpg yet, noticed that before I left for work my odometer was at 291 point something so thought I would reach 300 by the time I got to work. 291+11=302. Got to work and read 299.9. :confused: I had been watching since I rarely hit 300 miles before 1/4 tank and was going to make fairly easy this time. Point is I didn't drive the 11 miles I'm used to. I'll have to remember to check it with the Taco soon.
    I have seen for sure about the speed being off myself and wondered if the odometer would be correct. I've used my gps and drove by them electronic speed signs and both consistently give me 2 mph less (pending how fast I'm going I guess) then actual speed.
  9. Sep 28, 2011 at 5:27 PM
    David K
    That's fair... but the A-TRAC button has NO affect on anything unless you are in L4.
  10. Sep 28, 2011 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    GPS it. Use the Trip feature, and a GPS at the same time. Set both to "0" then set off on your drive. You will see the factory ODO (with stock tires) is dam near what the GPS will show.
  11. Sep 28, 2011 at 5:36 PM
    Goldstar225
    Goldstar225 Well-Known Member
    Tom
    Central Arkansas
    2011 Pre-runner SR5 4X2
    Deleted, didn't realize it was a 4X4 poll. I know RTFM
  12. Sep 28, 2011 at 5:37 PM
    David K
    This is a 4WD poll. Sorry!!
  13. Sep 28, 2011 at 5:37 PM
    TacoDawgfan
    Georgia
    Good Idea, never thought of using my GPS to go to work. Thing is kinda old and slower than hell to boot up and find the destination. But will have to try that some time. :cool:
  14. Sep 28, 2011 at 5:54 PM
    BritMike
    BritMike Well-Known Member
    NJ
    10 Black TRD OR
    37,568 miles tracked on fuelly over the past year - 19.9 mpg.
    Right now I'm getting 21-22 mpg but that'll drop in the winter to 17-18. I do the same 600 mile round trip each week so it's easy to compare slight changes in driving style and how they affect mpg.
    Two biggest differences - keep it below 70 on the highway and keep the ac compressor out of the picture, so no AC and no defrost (got to do the compressor off mod for defrost mode soon). Just leaving defrost on will knock off 1 - 1.5 mpg.
  15. Sep 28, 2011 at 6:06 PM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    welp, I meet the requirements from the OP.
    daily driving, 16-17 mpg, 90 highway. But I also have 33 BFG A/Ts, complete OME set up, and ATO rear bumper.
    I took the rear tire swing out off, and on the 2nd tank with it off I managed 17.5 mpg. I really couldn't say if the spare on the swing out affected highway mpg though. But the swing out itself weighs roughly 40 lbs.
  16. Sep 28, 2011 at 6:23 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    edit - already been covered.
  17. Sep 28, 2011 at 7:59 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    17. Combined city/hwy on 285/75/16
  18. Sep 28, 2011 at 8:21 PM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    In most months I average 19.6-20.7, with winter-blended fuel and winter driving it generally hits around the 17-18 mark. All this is basically a showroom stock '10 OR model with the exception of an AFE Pro Dry air filter, which I will say accounted for about a .3-.5 mpg increase with installation.
  19. Sep 28, 2011 at 8:24 PM
    sandjunkie
    Aaron
    OC
    Right, that's what I thought as well.
  20. Sep 28, 2011 at 9:40 PM
    Tarheelz2350
    Tarheelz2350 Well-Known Member
    Jon
    Dallas, NC
    10 MGM 4x4 TRD O/R DC
    Bilstein 5100's F/R, Tin Snip mud flap mod, Partial Debadge, Rear Diff Breather Mod, Rear Spring TSB, 265/75/16 Cooper Discoverer AT3's, Devil Horn's courtesy of Andres
    I've been right around 20 for a while now. Some off road/city mostly highway. I also stay around 60 or 65 dependent upon traffic. Just put 265/75/16's on so we'll see if that effects the mileage. Also just did a tune up also. I'll wait and see if that helps at all. Hopefully it goes up.
    On a side note, I'm doing the rear diff breather mod today. Think I'll ask the parts guy at the dealership why I had NGK R's in the driver's side cylinder bank and Denso's on the passenger side when I pick up what I need. Just thinking out loud, no intention to hijack OP's thread.
