4WD ECU Location
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Charlie213, Jun 5, 2017.
  1. Jun 5, 2017 at 2:44 PM
    Charlie213
    Charlie213 [OP] Well-Known Member
    San Gabriel Valley, CA
    06 OR TRD 6speed DCSB 4X4
    Ever since I opened up my front ADD and cleaned it out I've been getting the 4H blinking light. I've attempted to remove fuse, disconnect battery, and pound on it but it keeps blinking. I did the following per manual,:INSPECT 4 WHEEL DRIVE CONTROL SWITCH,
    INSPECT DIFFERENTIAL VACUUM ACTUATOR
    ASSEMBLY and now I'm stuck at step 3: INSPECT FOUR WHEEL DRIVE CONTROL ECU. I know I'm semi blind but I can't seem to locate it. I'm posting a pic of the passenger side compartment where the manual says it should be. Correct me if I'm wrong but am I looking for a black box that says 4WD ECU or is it something different?
  2. Jun 5, 2017 at 2:58 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Here is what the service manual says:
    Shveet and tomwil like this.
  3. Jun 5, 2017 at 3:05 PM
    Charlie213
    I'll go double check again. Does anyone have a live photo of what it might look like mounted on the vehicle?
  4. Jun 5, 2017 at 3:48 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    This is what it looks like:
    tomwil likes this.
  5. Jun 5, 2017 at 5:06 PM
    Charlie213
    Yes that's what I've been looking for and I don't have that in my pictures. Could it be that it was stolen and I never realized it until I attempted to use my 4WD. Each time I switch to 4WD I don't hear any sounds, Clicks, or movement. Before I would hear the click sound but now nothing. Should I take a better picture? Does anyone have a picture of their 4WD ECU mounted?
  6. Jun 5, 2017 at 5:11 PM
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    Lay in the floorboard facing up, you'll see it.
  7. Jun 5, 2017 at 7:19 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    @Charlie213 its over to the right towards the passenger door and straight up from where your glove box was (up high enough it's behind the upper dash)
    Here is a pic for reference with the wires going to it.
    Benny123 likes this.
  8. Jun 5, 2017 at 7:21 PM
    Charlie213
    I removed both wire harness from the 4WD ECU and one of the plugs has 2 slots with missing metal pieces. Looked inside and it doesn't seem like it makes contact with any metal. Could this be why I'm not getting any power to my font ADD? Does anyone have their ECU harness disconnected to confirm if it's normal or not?
  9. Jun 5, 2017 at 7:26 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Those two slots are unpopulated from the factory, no worries
  10. Jun 5, 2017 at 7:28 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Just because a plug has slots for wires it doesn't mean that they are used or populated. See the picture posted by another user you can see his doesn't have wires in that location either.
  11. Jun 5, 2017 at 7:29 PM
    Charlie213
    How am I suppose to check if I got the correct voltage if those 2 terminals are empty. The manual says terminals 1 &2 should have 10-14 volts when H2-H4 is selected?
  12. Jun 5, 2017 at 7:33 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Pin 1 & 2 are on the opposite end. Check this thread out, I've posted the ECU schematic and also something that should help you out in identifying pin numbers
    https://www.tacomaworld.com/threads/4lo-signal.489735/#post-15073050
  13. Jun 5, 2017 at 7:48 PM
    Charlie213
  14. Jun 5, 2017 at 7:50 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    You're welcome! I've attached the full schematic for you. FYI pins 1 & 2 in connector B are for the transfer case actuator, not the ADD actuator.
  15. Jun 5, 2017 at 7:57 PM
    Charlie213
    Assuming everything leads back to my font ADD which everyone has mentioned is the main problem, am I suppose to get the older version or the newest version which I believe is part number 41400-35033. This site shows as
    https://www.toyotapartsdeal.com/oem/toyota~actuator~assy~diffe~41400-35032.html
    the correct one. Just want to make sure I get the correct version.
  16. Jun 5, 2017 at 8:06 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    That I'm not sure on, you'd probably want to ask a dealer. Is the truck actually engaging 4hi but the green 4wd light keeps blinking or is it not even going into 4hi?
    SLG Customs LLC likes this.
  17. Jun 5, 2017 at 8:14 PM
    Charlie213
    Before I opened up the front ADD to clean it the green 4WD light would come on and stay blinking only when I used the selector switch but would turn off after I shut vehicle off. Now the green 4wd light automatically comes regardless of position of knob. Certain times both 4WD and 4LO come on.
  18. Apr 30, 2018 at 7:12 AM
    koth442
    koth442 Active Member
    Leon
    2009 TRD Off Road
    Stock
    So I was referencing this post to find my ECU. I'll go ahead and add some pics to help others down the road.
    1. Remove glove box.
    2. Remove this piece
    A8h5pXubAWAgqgKfGApxu5xFxfWP6RVaSHGYUCQL_0944c537f29115e914c83d7af3c91065c4fedf28.jpg
    3. Which reveals this view
    Hope that helps someone!
    Memphis and Shveet like this.
  19. Sep 22, 2018 at 11:25 PM
    Kevinkiger16
    Kevinkiger16 Active Member
    Kevin
    2007 tacoma 2.7 manual
    Did the ecu resolve your problem? I am having similar issues with my tacoma 07 2.7 Manuel I know for a fact my actuator on the t case and front diff work but I have a constant flashing 4 lo light on my dash and 4wd will not engage make noise nothing
  20. Sep 23, 2018 at 1:03 PM
    koth442
    Leon
    2009 TRD Off Road
    Stock
    It worked for a day then died again. I've been dragging my feet to fix it since.
