4WD ECU Location
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Charlie213, Jun 5, 2017.
  1. Oct 4, 2018 at 10:23 PM
    88Taco
    88Taco Well-Known Member
    Michigan
    Black 08 DCSB TRD Off-road.
    Rear diff breather mod. Block heater
    Any resolution on this issue? Having similar problems myself.
  2. Nov 20, 2018 at 1:07 PM
    Gregstukey
    Gregstukey Member
    Had a similar issue--intermittent green flashing and 4lo flashing. When I pulled the connectors for the 4wd ecu one of the female pin "receptacles" had a bunch of green corrosion in it. You could actually see it inside the white connector. I can also make the lights stop flashing by wiggle testing the harness when its plugged in. With the lights out 4wd will work normally. Not saying its your issue but it turned out to be mine...
  3. Jan 2, 2020 at 12:55 AM
    ToyoRideBFG23
    ToyoRideBFG23 Clifford, the big red Yota Beast
    So-Cal
    2011 Toyota Tacoma OR Edition 4WD
    Front: 2.5 Icons extended travel remote reservoir CDCV, JBA Offroad High caster Arms, Wheelers super bumps Rear: Bilstien 5125, 1.5” AAL, Other: Front tube bumper, FJ T-Case, 285/75/16 BFG KO2s, Black Rhino Chamber wheels -10 offset with 1.25”wheel spacers, Nilight Ditch lights and LED Fogs. Upcoming Mods: Hammer Hangers, Icon RXT leaf pack, Icon 2.0 VS Series Remote Reservoirs.
    Sorry to revive this old thread, but did you find out the cause to your problem? I’m diagnosing my truck for the same issue but tried checking everything and I’m stuck what else to check.
  4. Jan 2, 2020 at 6:00 AM
    88Taco
    Michigan
    Generally 4WD lights acting all crazy is an ADD problem. If you’ve already taken apart the ADD, cleaned and tested it, then I’d check the transfer case position sensors. There’s two on top of the t-case and bad connection or failures of those will also cause issues. If neither of those are the issue id guess 4WD ecu. Best of luck.
  5. Jan 2, 2020 at 6:35 AM
    koth442
    koth442 Active Member
    Leon
    2009 TRD Off Road
    Stock
    I'll have to check the position sensor on the transfer case. I'm still having problems and have very little motivation to work on it.
  6. Jan 2, 2020 at 8:08 AM
    88Taco
    Michigan
    Well we can’t help you with motivation but I’m sure that Tacomaworld can certainly help you figure out what’s wrong with your truck.
    koth442 likes this.
  7. Jan 2, 2020 at 9:18 AM
    Charlie213
    Charlie213 [OP] Well-Known Member
    San Gabriel Valley, CA
    06 OR TRD 6speed DCSB 4X4
    For my vehicle, it was the transfer case. The 4x4 system was never used by the prior owner.
  8. Jan 2, 2020 at 5:37 PM
    88Taco
    Michigan
    That’s just criminal. That poor truck.
  9. Jan 18, 2020 at 6:36 AM
    timawa15
    timawa15 Member
    2006 Silver Tacoma 4X4
    My ‘06 Tacoma started having 4WD problem. I ended up disassembling the front diff ADD, reinstalled it just to find out it was the transfer case actuator’s vacuum hose cracked open.
    Check wiring and hoses connections first before disassembling any parts saves you a lot of headaches.
    Lumberjackcoma and llamasmurf like this.
  10. Feb 11, 2020 at 9:28 AM
    bravinci
    bravinci Well-Known Member
    Brent
    British Columbia
    First Gen 4 door Tacoma
    Hey guys, fun fact, third gen Tacomas have the same issue! Thanks Toyota!! And thanks TW for the knowledge on how to fix it lol
  11. Jan 16, 2022 at 3:12 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Appreciate the info here. Replaced my actuator 2 years ago and had worked fine since then. However, over the weekend when I tried, its just flashing 4LO again. After a few reattempts by restarting it is working properly again, but going to look into the ecu to see if there is corrosion there like stated above that causes intermittent failure. I notice when there is no click there is no 4wd and 4LO flashes.
  12. Dec 29, 2023 at 2:58 PM
    SLG Customs LLC
    SLG Customs LLC Member
    2006 DBC Tacoma TRD offroad
    4 inch procomp lift kit ARB front bumper custom built rear bumper 36x10.50R16 CO-OP grip spur tires 4.0L bord out to a 4.6 stroker, 12-5-1 compression pistons 225Hp injectors TRD supercharger 7.62 lift cams ported and polished heads shaved 10 thousands with bigger valves. 5 Stage (Old school) EDGE performance CTS programmer und under drive pulleys, K/N cold air intake system pedal commander box
    Mine goes into 4hi but light in dash blinks
  13. Dec 29, 2023 at 3:09 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
