4wd fails to engage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Surf Rig, Nov 20, 2018.
  1. Nov 20, 2018 at 8:13 PM
    Surf Rig
    Surf Rig [OP] New Member
    New Jersey
    09 Tacoma Sport 4x4
    Hey guys,
    New to TacomaWorld. I have an 09 Tacoma Sport, 6 spd Manual Transmission. The 4wd has always had issues engaging, several months ago on the fly 4wd stopped working. If I stopped the vehicle it would engage. Several weeks ago I began having further issues when I stopped. I could usually get it to engage after banging on the transfer case, cycling the switch, driving in circles etc. After researching the threads here I thought I had found the issue with the ADD on the front diff. Removed the existing and took it apart, no corrosion or bent connectors. I've connected the motor to a battery and can confirm it is functional. The microswitch at terminals 3 & 4 reads 0 ohms when the switch is closed.
    I have the truck jacked up with all 4 wheels off the ground. I can confirm the transfer case actuator is engaging, front driveshaft spins when the truck is in gear and 4hi is selected. I have the ADD plugged into the harness but the fork is not moving when the selector is manipulated. Not sure what to check next.
  2. Nov 20, 2018 at 8:54 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You will have more luck in the 2nd gen forum probably.
    Comato$e likes this.
