4wd feels tight
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 17tacomalb, Dec 10, 2017.
  1. Dec 10, 2017 at 10:32 AM
    17tacomalb
    17tacomalb [OP] Active Member
    2017 taco lb
    Why when in four wheel high when going around a sharp corner slow the truck feels like it's tight and don' want to go. Normal?
  2. Dec 10, 2017 at 10:35 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
  3. Dec 10, 2017 at 10:36 AM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    The inside and outside tires are trying to rotate at different speeds. So if you aren't on a surface that allows the tires to slip some, it will feel like things are binding up.
    InfernoTonka and stealthmode like this.
  4. Dec 10, 2017 at 10:38 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    4x4 basics. Welcome to TW buddy. This place will make you 10x smarter and 10x poor - er .
  5. Dec 10, 2017 at 10:41 AM
    17tacomalb
    2017 taco lb
    Ok thx guys
  6. Dec 10, 2017 at 10:44 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Use the 4X4 offroad or on slippery streets. If you want to make a sharp turn like in a parking lot. Put the truck into 2wd to prevent binding.
    over60 and 2016Tacoman like this.
  7. Dec 10, 2017 at 10:46 AM
    AWDDude
    AWDDude Well-Known Member
    2017 Tacoma TRD Off Road DCSB, QuickSand
    its because we have 4x4 and not awd. when you turn the front wheel try to drive on a smaller circle than your rear wheels. An AWD system get around this by havng a center differential that allows for speed difference between the front and rear. 4x4 doesnt have a center diff just a transfer case that sends exactly the same speed front and rear.
  8. Dec 10, 2017 at 10:48 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Uhh
    Let me guess you were on pavement ?...
    Joe23 and 2016Tacoman like this.
  9. Dec 10, 2017 at 10:49 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Well, actually, what you are describing is a locked differential.
    In and AWD, there is a center differential that allows the speed of the drive shafts to be different. The taco doesn't have one. The binding he is referring to is that ALL wheels are traveling at different speeds and more importantly is that the front shaft is spinning at a different speed than the rear drive shaft. The center differential, like on a full time four wheel drive, combined with front and rear differentials, allow ALL wheels to travel at different speeds. :)
    RocTaco likes this.
  10. Dec 10, 2017 at 11:16 AM
    17tacomalb
    2017 taco lb
    So you guys suggest just turning the 4wd on and off especially when turning around or making sharp turns in a non slippery lot
    stealthmode and Slashaar like this.
  11. Dec 10, 2017 at 11:21 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Never turn on 4hi or 4lo, unless traction is an issue. In those modes, your tires need to be able to "slip", otherwise you'll damage the drivetrain. Never use on dry pavement.
    Joe23, HBMurphy, Slashaar and 2 others like this.
  12. Dec 10, 2017 at 11:32 AM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    My Toyota service rep told me that you must turn on the 4WD occasionally to keep all the components lubed up. Otherwise seals, diaphrams etc can dry out and break down.
    I don't have any open country fields or dirt/gravel roads to even occasionally use 4WD.
    Every few months I'll put 4WD on and go for a few miles on a straight stretch of paved road (no turns). Is this recommended?
    I am curious what everyone does, or can suggest, to occasionally keep the 4WD components in primo condition.
    boynoyce likes this.
  13. Dec 10, 2017 at 11:35 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    In theory, as long as you're going in a perfectly straight line, you should be fine. I personally would try to find a large gravel lot. Keep in mind, there are tons of trucks out there that don't engage their 4x4 for years, and don't have issues wwith seals and whatnot.
    InfernoTonka[QUOTED] likes this.
  14. Dec 10, 2017 at 11:38 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Its actually the fronts rotating at different speeds than the rears thats a problem. We have open diffs front and rear but we are locked at the transfer case.
    SRBRO5 and InfernoTonka like this.
  15. Dec 10, 2017 at 1:59 PM
    HBMurphy
    Paul
    So California Coast
    None
    Actually, I think the policy is, if you bought a 4wd truck, you should be out somewhere that you need it and use it once a month. Otherwise the Prius is a far more capable vehicle for city traffic.
  16. Dec 10, 2017 at 3:50 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    There is a nice stretch of straight road on my commute to work that I occasionally activate 4wd.
    I have been following this topic in TW since purchasing the truck.
    The consensus seems to be that as long as you aren't turning the wheels too much, it is ok to have 4wd on dry pavement, just to keep the parts lubricated.
    Have seen many members respond that the truck will be fine without this being done, but my plan is to keep my truck for a very long time.
    IMO, like most things, if you keep on top of seemingly insignificant maintenance issues now, your reward will be realized "way down the road" -literally, lol.
  17. Dec 10, 2017 at 4:03 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    gorgeous dog dude
  18. Dec 10, 2017 at 4:07 PM
    Joe23
    they say to do so. Which is interesting because yes if you dont use it, it will seize. But htey don't mention it for 4lo. one guy I wheel with has no 4lo because the actuator is seized. I'm thinking this is exactly why. 4Lo was never used.
    But yes straight line on pavement is the best option. But even better option would be find some open country roads and have some fun ;)
    I truthfully never do the pavement. But then again I go off road almost every weekend in the summer months and in the winter months I'm in 4hi cause of the snow lol.
  19. Dec 10, 2017 at 6:31 PM
    anthony250f
    Anthony
    San Diego, CA
    Thanks man!
  20. Dec 10, 2017 at 6:37 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I have yet to see a drivetrain or any part of a vehicle legitimately damaged due to binding from 4wd.
