4wd front driveshaft spins freely
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timothom, Jun 21, 2016.
  1. Jun 21, 2016 at 6:26 AM
    timothom
    timothom [OP] Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    I was greesing the drive train on my 2014 4wd when I noticed that I can spin the front driveshaft by hand. This is with the vehicle parked and in 2wd. I understand this is normal.
    I'm wondering if the front drive shaft spins or is stationary when I'm driving in 2wd? Is there something in the front diff that decouples the drive shaft from the CV joints?
  2. Jun 21, 2016 at 6:29 AM
    rockguitar316
    rockguitar316 Well-Known Member
    Adam
    Dayton Ohio Area
    Now: 2016 WRX stage 2 377hp/350tq. Then: 2016 TRD Sport DCSB 6MT (don't kick me!)
    My turd gen spins in 2wd too. Before greasing mine my friend went underneath so I could move it SLOWLY to get to the zerks but yeah it spins freely even in 2wd.
  3. Jun 21, 2016 at 8:32 AM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    yup, if it's not engaged in 4WD it should spin freely. Makes greasing a lot easy too :bananadance:
    irish_11 and shakerhood like this.
  4. Jun 21, 2016 at 9:05 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    If the truck is not in 4wd, the front shaft will spin by hand...if you put it in 4wd, it will not spin.
    irish_11 likes this.
  5. Jun 21, 2016 at 10:03 AM
    timothom
    Yea, but if spins freely, something must be in that front end disconnecting the CV axels from the drive train, right? I can spin the shaft and the wheels are on the ground.
    I'm wondering what the mechanism is to do this in the front end. I understand how a transfer case works, but I didn't know the front end had something in it too.
  6. Jun 21, 2016 at 12:00 PM
    Pigpen
    Dan
    Northwest Montana
    The ADD - automatic differential disconnect
    shakerhood likes this.
  7. Jun 21, 2016 at 1:04 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    to elaborate, the ADD decouples the passenger side front driveline between the diff and inner CV
  8. Jun 21, 2016 at 1:12 PM
    timothom
    Ah, after googleing for the "Toyota Automatic Differenetial Disconnect", I see now what is going on.
    So I'm correct to assume the front propeller shaft doesn't rotate much when driving the vehicle is not in 4wd?
