4wd Grinding and not moving
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stevets, Dec 12, 2023.
  1. Dec 15, 2023 at 1:43 PM
    stevets
    stevets [OP] Member
    steve
    2017 tacoma TRD
    The problem turned out to be the transfer case.
    After I pulled off the actuator, I found the rod was only moving a small amount. and it was not all the way in to the 2wd position to begin with. I believe that what little movement it had was enough for it to go in to some sort of neutral position between 4hi and 4lo, and that is why the truck would not move and made grinding noises when I put it in 4hi. The rod should have 3 distinct detent positions which are obvious, and you should be able to move it by hand.
    I bought a used transfer case assembly at a nearby salvage yard for $400. I installed it, timed the actuator, and all was good.
    FYI its a bit of work to replace a transfer case. There are 8 bolts that hold it on and 3 of them are quite difficult to reach. I definitely recommend having a quality impact driver and an assortment of extensions and universal joint adapters.
    All good now. thanks to you all for your help
    JSX, ricco333, gilligoon and 13 others like this.
  2. Dec 15, 2023 at 2:28 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Appreciate you circling back with the diagnosis and fix. :thumbsup: It sounds like it may not have been engaged or used very often.
    Chew, Canadian Caber and Junkhead like this.
  3. Dec 15, 2023 at 3:23 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    The range sleeve between high and low is the only neutral that exists so this all makes sense. Figured it wasn't the 2wd to 4wd shift collar. Good find.
    BigWhiteTRD and Williston like this.
  4. Dec 15, 2023 at 4:53 PM
    Williston
    FWIW, I cannot recall ever seeing a post in here with a confirmed Transfer Case failure diagnosis.
    Rare bird.
    Chew likes this.
  5. Dec 15, 2023 at 6:58 PM
    stevets
    stevets [OP] Member
    steve
    2017 tacoma TRD
    I dont know for certain what happened internally with the transfer case in my truck. Like I mentioned before, I just bought it a week ago, knowing the 4wd didnt work.
    However, there was definite evidence of recent repairs. the actuator was definitely removed.
    One theory I have is, the previous owner in an attempt to replace the transfer case actuator, may have removed the transfer case, split the case and replaced the entire actuator and rod. And perhaps made some mistakes assembling the shift forks.
    I suppose I could open the old transfer case and take a look. Maybe this weekend.
    gilligoon, BigWhiteTRD and Bertw192 like this.
  6. Dec 15, 2023 at 8:56 PM
    ShimStack
    Ben
    NC
    I'm guessing it was all messed up and moving the range sleeve when it should've been shifting the 2/4 fork. Knowing it was messed with recently makes this more likely.
  7. Dec 15, 2023 at 9:07 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Definitely tear apart the old unit and let us know your observations. Always good info to get ‘lessons learned’, whether this was neglect (lack of use of 4wd), normal wear-and-tear, or abuse / rust / other.
    Canadian Caber likes this.
  8. Dec 16, 2023 at 12:00 AM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    @stevets Nice work on diagnosing and fixing the problem. And thanks for posting the resolution for us to read. It drives me crazy when I don't find out how the story ends. :thumbsup:
    CB350G and stevets[OP] like this.
  9. Dec 16, 2023 at 2:59 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I love it when someone dives in with no fear and solves an issue like this. Well done OP!
    gilligoon, CB350G and stevets[OP] like this.
  10. Dec 16, 2023 at 12:49 PM
    woodsy
    Ohio
    OP had it handled in less time than it would have taken to me to post questions about it on TW. :)
    gilligoon and stevets[OP] like this.
  11. Dec 16, 2023 at 12:56 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Thanks for the repair update OP... I guess i have to say it isnt ALWAYS the actuator, that is for sure.
    (I am still sticking with my 'its never the 4wd ECU' theory)
    stevets[OP] and ShimStack like this.
  12. Dec 17, 2023 at 5:10 PM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Thanks for confirming what I had originally suspected and posted. Hopefully no other major issues you come across
