4wd hi range acceleration problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by fireturk41, Feb 27, 2011.
  1. Feb 27, 2011 at 9:18 AM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    hey yall, ive developed a new problem, whenever im in 4hi, the truck will not accel over 3000rpm, even with the gas all the way down. it just gives up. but if switched to 4lo it will redline all day long if i let it, i dont know why though, this is recent to my truck and has occurred several times in the last week...btw 2002 toyota tacoma, 3.4 v6 at 4x4 with manual hubs
  2. Feb 27, 2011 at 9:20 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Have u tried shifting manually? Like dropping the gearshift all the way to L?
  3. Feb 27, 2011 at 9:22 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    no i didnt in 4 hi, i only do that in 4 lo usually
  4. Feb 27, 2011 at 9:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is the problem only in 4hi? What does it do in 2hi?
  5. Feb 28, 2011 at 4:10 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    2hi no problem, i can redline it all i want, it is only in 4 hi
  6. Feb 28, 2011 at 4:25 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Try downshifting and see what it does.....
    The only thing I can think of, is Toyota could've put some limitations in the computer programming for 4hi to keep your speed down. ?????
  7. Feb 28, 2011 at 6:41 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I dont think there is a limiter. While I have yet to be this stupid, there was somone who bosted going 100+ in 4 hi :facepalm:
    I cant help you more than that, sorry.
