4WD in rain OK?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by puckstopper55, Sep 28, 2011.
  1. Sep 28, 2011 at 10:30 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    You could probably engage 4WD on wet pavement going in a straight line for a few minutes but I wouldn't do it in my truck (got hundreds of miles of dirt roads 5 minutes from the house.):mudding:
  2. Sep 28, 2011 at 10:52 AM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    OT but your sig is freakin awesome!
    <airplane guy
  3. Sep 28, 2011 at 11:02 AM
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    this guy knows
  4. Sep 28, 2011 at 11:18 AM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    Just put it in 4x4 on the regular road and just drive straight, then no need worry about binding
  5. Sep 28, 2011 at 2:40 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    i say use it when ever you dont feel safe, if you fish tail and hit something youll be so mad you didnt use your 4wd
  6. Sep 28, 2011 at 5:21 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The VSC is a big help in rainy weather if your bed is empty... Almost feels like you are in 4WD when you accelerate on a turn in the rain... and yes, without VSC, just an empty bed truck will fishtail easily in 2WD... NOT so in 4WD. I have done it many times. The front and rear are locked together in 4WD... so this prevents the back end from accelerating 'ahead of' the front... or trying to (fishtailing).
  7. Sep 28, 2011 at 5:30 PM
    2011TacoBeav
    2011TacoBeav Well-Known Member
    Bret
    Oregon
    2012 Sr5 v6 auto DCSB
    Self made rear bumper Colormatched Bush Wackers CB Center console lock box Camo seat covers Weathertech Digi blk Bilstein 5100s set at .85 Eibach coils LR UCAs Rear 1.5" block
    WHat kind of damage can be caused by this "binding" as a result of driving on dry pavement in 4wd?
  8. Sep 28, 2011 at 5:36 PM
    David K
    Exactly... tires on slippery surfaces can slip and give... Gears cannot slip and give... they just break teeth!
  9. Sep 28, 2011 at 5:37 PM
    2011TacoBeav
    Bret
    Oregon
    I don't know what I'd do with out you man!
    Your always on here when I am and are always able to answer my silly questions! Thanks a ton!
    Yeah I did experience some binding driving in 4x. but i've only done/experienced it once. knew something was seiously wrong and asked you guys!
    Thanks for the help... I guess I have a perfectly good excuse to get my truck all muddy at least once a month! ha
  10. Sep 28, 2011 at 6:49 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Every time I have tried it, it's been nearly impossible to get the truck back into 2wd. To me, that indicates drivetrain bind, and damage waiting to happen.
    The last time I tried it was on a truck that had a manual shift transfercase, the lever physically would not move no matter how hard I yanked on it. Had to pull off the pavement and do a burnout in a straight line to unbind the drivetrain. Never done it since.
  11. Sep 28, 2011 at 8:02 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    no. and it wont help you in rain. You need to inflate your tires and put skinnies on to prevent hydro
  12. Sep 28, 2011 at 8:14 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    you should be fine, just slow down on wet roads, last spring it rained from the end of May to the first week of July and i never used 4x4 for any of it, even on the gravel roads when they are muddy. 2nd gens are heavier than 1st gens and hold the road a lot better due to the weight, will use it though on snow and ice for sure since we get a lot of it here in the winter.
  13. Sep 28, 2011 at 8:17 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The sun visor card says to avoid making sharp turns in 4WD. That matches my experience. Binding is only felt when I pull into a driveway, etc. Even highway cloverleaf off ramps aren't an issue - there isn't a difference between front and rear wheel speeds when the curve is gentle.
    I use 4H all the time in the rain. Helps me get a better launch from a standstill. Engine braking is also more effective in 4H. I put it back to 2H before I turn into my driveway. It disengages instantly every time.
    BTW, the 4WD system is designed to operate at up to the truck's top speed. The only difference between 2H and 4H is the front prop shaft doesn't turn in 2H. That's also the only reason you need to go into 4H monthly, to lubricate the U-joints in the front prop shaft. In 4L, your top speed is basically limited by redline, since the engine has to turn 2.57x as fast as in 4H, at any given road speed.
  14. Sep 28, 2011 at 8:19 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    i sometimes put it in 4wd when im bombin down the mountains while its raining really hard - but thats it.
  15. Sep 28, 2011 at 8:19 PM
    #35
    slmgt
    slmgt Well-Known Member
    Greater Seattle Area
    11 TRD Sport w/ JBL DCLB V6 AT
    Husky floor mats (Fr and Rr)
    If you are a cautious driver, few safety systems will even need to be engaged. That's why ABS, VSC, RSCA, etc exist... So while you could use 4x4 if you don't feel safe, what about when things feel safe and start swimming up a creek, then what??
    Are you also a driving instructor, because bad habits often die hard? :facepalm:
    (note: just the 'bombing' down the hill in the rain part)
  16. Sep 28, 2011 at 8:23 PM
    #36
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    wat will gte lubed by throwing it in 4x4 for 10 miles a month? ive used 4wd twice for a total of 5 mins since i got the truck.. is that bad?? lol
  17. Sep 28, 2011 at 8:25 PM
    #37
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If you are fishtailing in rain on pavement , you don't need 4wd , you need to slow down .
  18. Sep 28, 2011 at 8:28 PM
    #38
    especk
    Erik
    Redding, CA
    No, but it inspires confidence! haha ya dont listen to me.
  19. Sep 28, 2011 at 8:28 PM
    #39
    KenLyns
    Belly of the Beast
    Hard to say. The front propeller shaft needs to turn once in a while to spread the grease out in the U-joint pins. That's about it. Are you greasing the propeller shafts with a grease gun once a year as per the maintenance booklet? You know what happens when you don't grease them? http://www.tacomaworld.com/forum/su...e-piece-driveshaft-blew-up-while-driving.html
    A FWD vehicle at the same speed would handle perfectly fine. 4WD makes up for the truck's nose-heavy weight distribution.
  20. Sep 28, 2011 at 8:35 PM
    #40
    OZ-T
    Peter North
    British Columbia
    Without trying to sound like a dick , where I live it rains for 6 months straight , NOBODY here uses 4WD on pavement , ever .
    Maybe you guys have slippery pavement .
