4wd in the rain?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nastyblowpop, Mar 6, 2010.
  1. Mar 6, 2010 at 5:56 PM
    nastyblowpop
    nastyblowpop [OP] Well-Known Member
    Long Beach, CA
    08 DC 4x4 rugged trail
    i have the stock rugged fails still (havent had enough money to upgrade yet) and they are at less than 25% tread left. is it bad to run my truck in 4WD HI in the rain to keep me from hydroplaning?
  2. Mar 6, 2010 at 5:58 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Well it won't keep you from hydroplaning. Slowing down is the only thing that will keep you from doing that. 4WD might help though. It's okay on wet roads I think.
  3. Mar 6, 2010 at 6:04 PM
    nastyblowpop
    Long Beach, CA
    ok sounds good, it just really sucks driving 30 on the fwy when everyone else is driving normal. so just confirming in water on a regular road 4wd wont help with traction on the front tires?
  4. Mar 6, 2010 at 6:05 PM
    DeathBound
    DeathBound Well-Known Member
    Jay
    Mississippi Gulf Coast
    2010 Tacoma SR5 4X4
    4wd don't help with traction on wet pavement, it probably makes it worse.
  5. Mar 6, 2010 at 6:13 PM
    SilverStreak05
    SilverStreak05 Well-Known Member
    NorCal
    2005 4x4 TRD Off-Road
    DR coilovers, DR rear reservoir shocks, Deaver custom 11 pack leaf springs
    Huh?
    Nothing wrong with using 4WD in the rain. I'm pretty sure even the owners manual says to do so when it's heavy. Just make sure the ground is wet enough that your tires will actually have slippage.
  6. Mar 6, 2010 at 6:31 PM
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    i use 4wd in the rain, as for making it worse... wtf, really, meth maybe, dont know why you would say that. it wont hurt, you wanna use 4wd in heavy rain go for it. i do and no issues. many people do, and it does help with traction, people who say different prob dont have exp, go into a parking lot in heavt rain in 2wd and 4 wd, see which one get you around better 4wd, enjoy buddy
  7. Mar 6, 2010 at 6:32 PM
    DeathBound
    Jay
    2010 Tacoma SR5 4X4
    I was mainly thinking about the puddles we have down here on the interstate. The more drag the worse it is. Sorry if it's not the same where you are at.
  8. Mar 6, 2010 at 6:34 PM
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    yeah, throughpuddles hydro plain will happen with 2 or 4 or 6 or 8 wheel drive, speed vs water depth vs whatever formula = hydro plain. no hard feelings...no worries bro
  9. Mar 7, 2010 at 10:25 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    X2
    Why do you think AWD is so good in cars in bad weather? AWD is 4WD with a middle differential for use on dry pavement, too.
  10. Mar 7, 2010 at 11:29 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Yes it will help. If you half the torque to the rear wheels you'll have less likely hood of spinning out. Second your rear is more likely to break out than the front on these trucks cause the end is so light. I've used 4wd on wet pavement and it helped tremendously.
    How does that work? Drag is caused via friction. Whether you have power going to the back or the back and the front, you still have 4 wheels on the ground. While trying to be tactful, I'm not entirely sure you know what you're talking about, or else you're wording what you want to say very wrongly.
  11. Mar 7, 2010 at 11:41 AM
    DeathBound
    Jay
    2010 Tacoma SR5 4X4
    I'm wording what I want to say very wrongly.
  12. Mar 7, 2010 at 11:53 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Then what are you trying to say exactly?
    And before you respond trying to tell me that I committed the same faux pas you did...I didn't.
  13. Mar 7, 2010 at 11:57 AM
    DeathBound
    Jay
    2010 Tacoma SR5 4X4
    I don't know what your problem is, I admitted that I said it wrong, that should be good enough.
  14. Mar 7, 2010 at 12:09 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I've read some drive in 4wd in the rain, but I wouldn't take the chance in my truck. It doesn't take much to bind up while turning... if you go through an area with minimal slippage your asking for trouble. I've read a few posts here where guys drive in 4wd in the rain and wonder why their truck acts like it's got alot of resistance while turning and makes grinding noises.
  15. Mar 7, 2010 at 12:40 PM
    YoterHead
    YoterHead Well-Known Member
    Completely not worth it use 4wd on wet pavement. What purpose is it serving? Just like snow, the only thing 4wd is going to do is help you accelerate. Hydroplaning, as stated above, is based on your vehicle speed and your tread depth. 4wd is not going to help with either of those.
    Also, you're relying on your tires ability to slip on wet pavement. Not only when turning, but driving straight. If your differentials are even slightly off or your tires are different sizes slightly, then you'll have one going faster than the other and create binding which is going to wear down your truck.
    The best thing to do is drive slower. Let off the accelerator if you hit standing water.
  16. Mar 7, 2010 at 1:21 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I'm an ass, could be source of the problem. I just wanted to nip it in the bud if you thought I used incorrect spelling. I don't have an issue with you.
    With 4wd you're halving the power to the rear wheels. So if you do hydro plane it decreases the likely hood that the rear end will break loose. Additionally with engine braking it also serves to use all 4 wheels to slow the vehicle.
  17. Mar 7, 2010 at 1:39 PM
    YoterHead
    When you're hydroplaning you don't have contact with the pavement. You go in the direction that you were going when you hit standing water. Halving the power to your rear wheels would have nothing to do if you hydroplane or not.
    If you want to rapidly accelerate through a turn, then you're better off in 4wd, but not just driving down the highway. If you need full time 4wd on wet pavement, you're doing it wrong.
    Don't waste the gas, just drive smart. If you want AWD get a Subaru.
  18. Mar 7, 2010 at 1:46 PM
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    i dont get how people say 4wd in adverse driving conditions is the same or worse than 2wd. it "may" not be the best for the mechanics behind the truck, or it may not be wrong at all, but come on, be freakin real here, 4wd is always better than 2wd as far as control goes....if not, why the hell are more and more auto manufacturers making awd models...its becuase w wheels turning is better than 2, esp when the 2 only is the rear. we should not act as if when hydroplaning, its a 1-2 min affair. its a brief moment, but in the brief moment, with 2wd, the end can slip out, but with 4wd if it does slip out, the front is still pulling and helping to keep direction. light reain, wet pavement, no idont see why its needed, but heavy downpours where highway speeds are needed, and lots of puddles exist, 4wd is fine. and prob expected
  19. Mar 7, 2010 at 1:53 PM
    YoterHead
    Heavy rains/downpours with highway speeds just slow down. Agree to disagree I guess.
    A lot of manufacturers AWD is really a front wheel drive that will send power to the rear wheels when the front slips. Most people don't know the difference or don't care.
  20. Mar 7, 2010 at 2:27 PM
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    might as well sell my 4 wheel drive for a 2 wheel drive. dumbasses.
