4wd indacator flashing won't turn off
Discussion in 'New Members' started by Siknezz805, Jul 2, 2016.
  1. Jul 2, 2016 at 7:56 PM
    Siknezz805
    Siknezz805 [OP] Active Member
    Ed
    Santa maria
    Toyed
    Icon stage 4
    I have a 2016 Tacoma off road, went off reading today after switching to 2wd my 4wd indacator still flashes and won't turn off any one with this issue and how to fix it?
  2. Jul 2, 2016 at 8:00 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Did you try coming to a complete stop, switching it back to 4WD, then to 2WD and slowly rolling forward or backwards a few feet? You might feel a slight lurch, and it should shift.
  3. Jul 2, 2016 at 8:07 PM
    Siknezz805
    Ed
    Santa maria
    Toyed
    Icon stage 4
    Yes I did that before n did that now lights still on , thanks tho!
  4. Jul 2, 2016 at 8:08 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Is it in 2wd and the light is still on?
    Or will it refuse to get out of 4wd?
  5. Jul 2, 2016 at 8:20 PM
    Siknezz805
    Ed
    Santa maria
    Toyed
    Icon stage 4
    Yes it's 2wd but the 4wd indicator is flashing.
  6. Jul 2, 2016 at 8:22 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Try resetting the ECU. Disconnect battery for the night. Connect it in the morning and see if that fixes the problem. If not, I'd make an appointment with the service department.
  7. Jul 2, 2016 at 8:22 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Did you try putting it back in 4W putting truck in neutral and back to 2W
  8. Jul 2, 2016 at 8:23 PM
    Siknezz805
    Ed
    Santa maria
    Toyed
    Icon stage 4
    I already made appointment, should I still disconnect the battery?
  9. Jul 2, 2016 at 8:24 PM
    eon_blue
    Azusa, CA
    Huh, thats weird...if it was still in 4x4 it should stay solid but flashing indicates it thinks you want to go into 4wd but it won't for some reason.
    Have you tried re-engaging 4wd to see if it'll engage? Hopefully it does otherwise it may mean somethings wrong with your 4wd system.
    edit: @303tacoma beat me to it
    303tacoma likes this.
  10. Jul 2, 2016 at 8:26 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    In that case I wouldn't. I'd make sure I was able to physically show them the light.
    eon_blue likes this.
  11. Jul 2, 2016 at 8:28 PM
    303tacoma
    Rebecca
    Mine flashed like that one time this is what worked for me.
    eon_blue[QUOTED] likes this.
  12. Jul 2, 2016 at 8:33 PM
    Siknezz805
    Ed
    Santa maria
    Toyed
    Icon stage 4
    Yes it is weird that is doing this I hope is just a sensor that's wrong truck is new only got 3k on odo lol
  13. Jul 2, 2016 at 8:37 PM
    eon_blue
    Azusa, CA
    What kind of terrain were you on when you went off-roading today? Did you happen to drive on any pavement or solid surface with 4wd still engaged? It happens, it can be easy to forget you're in 4hi when you jump back on the main road (happened to me before, luckily it didn't result in any damage). Just trying to think of reasons why it would go haywire especially on a brand new truck. New vehicles these days have so many safety features that I wouldn't be surprised if it sensed something like that and set off a code of some sort. Regardless, fortunately the warranty should cover it. At least you aren't stuck in 4lo or something lol.
  14. Jul 2, 2016 at 8:37 PM
    303tacoma
    Rebecca
    If none of the above work the dealership will cover you
    Mine was stubborn coming out of 4wdlow the first few times have to exercise it haha
    You should be ok as long as it's not locked in 4wd
    Edit; @eon_blue beat me to it Hahahaha
  15. Jul 2, 2016 at 8:39 PM
    eon_blue
    Azusa, CA
    get out of my head already! :eek: lol
  16. Jul 2, 2016 at 8:41 PM
    303tacoma
    Rebecca
    I know right
  17. Jul 2, 2016 at 8:44 PM
    Siknezz805
    Ed
    Santa maria
    Toyed
    Icon stage 4
    It was mostly sand at pismo dunes had a good time until we went home and seeing that flashing it drove find fine just worried I guess.
  18. Jul 2, 2016 at 8:55 PM
    97handmedown
    97handmedown Well-Known Member
    Tyson
    1997 Tacoma 4x4 Single Cab
    3", wheels, tires, old man seat covers
    Is that the only light thats on? Or did any other lights come on originally?
  19. Jul 2, 2016 at 8:57 PM
    Siknezz805
    Ed
    Santa maria
    Toyed
    Icon stage 4
    Yes that s the only light on
  20. Jul 2, 2016 at 9:01 PM
    97handmedown
    Tyson
    My brother (2nd gen) has had his light stuck flashing before. He found some loose terrain (soft dirt) and just switch from 2wd to 4 hi and low over and over back and forth and after ending on 2wd one time it finally released 4wd.
    Does the owners manual say anything about a flashing 4wd light being a failure warning?
