4wd indacator flashing won't turn off
Discussion in 'New Members' started by Siknezz805, Jul 2, 2016.
  1. Jul 6, 2016 at 10:42 PM
    #61
    eon_blue
    Azusa, CA
    huh, I would've figured in this day and age with all the technology these cars and trucks have, that it would've stopped the transition from 2hi to 4low if you weren't under the right circumstances...
    Anyway, lesson learned. Always always always shift into 4lo at a complete stop, in neutral or clutch in (manual trans). And never go over 10, 15mph tops in 4lo. That seems to be another thing a lot of people on here talk about doing which is really bad for your transfer case.
  2. Jul 6, 2016 at 10:42 PM
    #62
    eon_blue
    Azusa, CA
    I don't know how 2016's work, but I can see someone in a first gen (like mine) trying to force it and breaking something that way.
  3. Jul 6, 2016 at 10:43 PM
    #63
    Launch21v
    Launch21v Well-Known Member
    Fontana, CA
    16 TRD sport dclb 4x4 tech pack w/jbl white
    I do. I have one
  4. Jul 6, 2016 at 10:44 PM
    #64
    Launch21v
    Fontana, CA
    It sounds like the dealer might be trying to blame you. Unless you were driving too fast in low or drove on the pavement all over in 4wd not sure how it would break on a new truck
    DustStorm4x4 likes this.
  5. Jul 6, 2016 at 10:47 PM
    #65
    eon_blue
    Azusa, CA
    It's kind of hard to read the OP's post a few ones back but that's kinda what I'm leaning toward too...going too fast in 4low. That'll overheat your transfer case right quick, depending on how fast you're going. I assume the 2016's will just flash at you if you try and put them into 4lo without being at a stop?
  6. Jul 6, 2016 at 10:48 PM
    #66
    Launch21v
    Fontana, CA
    That's correct and beep like hell
  7. Jul 6, 2016 at 10:51 PM
    #67
    Siknezz805
    Siknezz805 [OP] Active Member
    Ed
    Santa maria
    Toyed
    Icon stage 4
    No that wasn't the issue, the issue I shifted 4h then later to 2wd which I think I shoulda have stop n put neutral shift to 2h that's when I heard this loud noise man hurted my ears is like missedmshifting you know!
  8. Jul 6, 2016 at 10:53 PM
    #68
    97handmedown
    97handmedown Well-Known Member
    Tyson
    1997 Tacoma 4x4 Single Cab
    3", wheels, tires, old man seat covers
    I drove my 1st gen in snow up to 40 mph in 4 low. That was 5th gear mind you. Had to use low because I haven't re-geared yet :annoyed:
    Never had any issues. But mine isn't a fancy little button I guess.
  9. Jul 6, 2016 at 10:54 PM
    #69
    Launch21v
    Fontana, CA
    Shifting to 2wd from 4 hi can be done on the fly without stopping.
  10. Jul 6, 2016 at 10:58 PM
    #70
    eon_blue
    Azusa, CA
    Something was wrong with your truck then, it wasn't you. You can shift from 2wd to 4hi or vice versa while moving no problem, so long as you're in a relatively straight line and going under 55mph (65?). I never go that fast when making the transition so it never really matters, but I shift from 4h to 2wd all the time with no issues.
    303tacoma likes this.
  11. Jul 6, 2016 at 11:00 PM
    #71
    97handmedown
    Tyson
    I thought it was recommended to be going under like 15 mph to do the 4wd shift?
  12. Jul 6, 2016 at 11:04 PM
    #72
    eon_blue
    Azusa, CA
    line #2
  13. Jul 6, 2016 at 11:05 PM
    #73
    eon_blue
    Azusa, CA
    That's for 4hi, 4lo you have to be at a stop and in neutral. Although with a manual trans I've been able to get 4lo to sync while still rolling forward a bit, so long as I have the clutch pressed in all the way. Not recommended though
  14. Jul 6, 2016 at 11:08 PM
    #74
    97handmedown
    Tyson
    Damn. It would scare the jeebus out of me if I was doing almost 60 mph and realized I probably needed the 4wd about now. I think I would have already thought that far ahead. haha
    Well OP, glad they got you taken care of. And THANKS for actually letting us know what happened.
    303tacoma and eon_blue like this.
  15. Jul 6, 2016 at 11:09 PM
    #75
    Siknezz805
    Ed
    Santa maria
    Toyed
    Icon stage 4
    Always keep to 4h at most times lol, unless you need to use 4l. What do you guys use more on 4wd?
  16. Jul 6, 2016 at 11:10 PM
    #76
    eon_blue
    Azusa, CA
    I feel the same way, but apparently it's designed that way for when you're in a situation at high speeds where you realize you might suddenly need traction (icy roads?)...even under those conditions I don't know why someone would be going 60 mph lol.
    97handmedown[QUOTED] likes this.
  17. Jul 6, 2016 at 11:12 PM
    #77
    eon_blue
    Azusa, CA
    I live in Southern California so I only ever use 4wd recreationally. That being said, it's mostly 4lo that I need. I usually go into 4hi once I hit the fire roads but when I get deep into the trails I run, I crawl along in 4lo the majority of the time...1st to 3rd gear, never more than 10 mph or so.
    edit: sorry @97handmedown I accidentally quoted your post on this originally
  18. Jul 6, 2016 at 11:13 PM
    #78
    97handmedown
    Tyson
    With 237,000 miles on my 2.7 and big tires.... 4 lo :(
    Unless I'm just trying to tear apart a muddy field where I can just spin the tires and keep the RPM's up then I'm in 4 high. But if I'm climbing any incline or any obstacle or soft/deep terrain (sand, snow, deep mud, etc.) it's all low for this 1st gen.
  19. Jul 6, 2016 at 11:15 PM
    #79
    97handmedown
    Tyson
    But one day when funds are abundant and my motor finally dies.....
    I dream of regearing, a locker, a supercharger, and a fresh 2.7
  20. Jul 6, 2016 at 11:17 PM
    #80
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
