4wd is on but doesnt work
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CementTaco74, Dec 27, 2022.
  1. Dec 30, 2022 at 3:20 PM
    CementTaco74
    CementTaco74 [OP] Member
    2019 cement tacoma TRD-offroad
    6 inch lift 35 inch falken wildoeaks
    Maineah I will check that out!
  2. Dec 30, 2022 at 3:21 PM
    CementTaco74
    i have not. I havent had the space to do it but i will check on my next days off!
    crazysccrmd[QUOTED] likes this.
  3. Dec 30, 2022 at 3:28 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Maybe someone removed the front drive shaft when they installed the lift? Back in the days that was fairly common.
  4. Dec 30, 2022 at 3:34 PM
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    Disable the TCS.
    I got stuck off-road in snow, TCS was freaking out. Turned it off, worked like a normal 4wd would.
    CaptainBart45 likes this.
  5. Dec 30, 2022 at 3:45 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    :oops:
    He would’ve definitely heard if he snapped a CV. Also looks like he doesn’t spend too much time off-road.
    Chew likes this.
  6. Dec 30, 2022 at 3:45 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    What’s TCS?
  7. Dec 30, 2022 at 3:52 PM
    Sand_In_My_Taco
    NOR*CAL
    The traction control thing.
    Looks like a truck with little slippery lines coming out of the tires. Button should be on your overhead area where the MTS selector is. It's basically the system that cuts power to prevent slipping and whatnot. Don't qoute as I'm sure I'm not fully correct but any time I go off-road I turn that off otherwise I will "get stuck" in a patch of loose dirt.
  8. Dec 30, 2022 at 4:02 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    You meant TC. It’s actually very useful in 95% of the time when off-road, much better than just a simple open diff. In some snow or sand situations TC has to be fully turned off in order to get momentum.
  9. Dec 30, 2022 at 4:24 PM
    trail.taco
    trail.taco Well-Known Member
    2019 Tacoma Trd Offroad
    Beadlocks, 35s, Mid Travel
    Put it in 4wd and park it. Get under and spin the front driveshaft. If it spins by hand somethings wrong. If it doesnt spin by hand then 4x4 is engaged. Don’t listen to anyone blaming it on your tires or your lift. People on tacomaworld are delusional
  10. Dec 30, 2022 at 4:46 PM
    CementTaco74
    Trail.taco
    i will check this out to see if it spins. Thank you!
  11. Dec 31, 2022 at 12:52 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Not exactly. If only one of the two actuators is engaged your driveshaft won't spin by hand but yet you "won't have 4wd".
    I do think OP has everything working fine and just doesn't know what to expect/look for.
    Speedfreak likes this.
  12. Dec 31, 2022 at 4:25 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    This only tests the function of 1 actuator... if only one is working, the shaft will not spin. In order to verify if both are working correctly, you need to lift one front wheel while in 4wd and see if it spins free... it it does then 4wd is not engaging... if it will not spin free then it is locked into 4wd.
    Without preforming this simple test, we can not help you with further diagnostics of your drive system. This is a basic test for functionality of the 4x4 system. Basically if the wheel does not spin in 4wd, the system is working correctly. If the wheel spins in 4wd then you have an issue and we can move on from there...
    kherron likes this.
  13. Dec 31, 2022 at 6:04 PM
    CementTaco74
    I will be jacking it up and testing it. Will keep you guys posted once more is figured out!
