4WD issue? 6MT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mack7n, Jan 3, 2019.
  1. Jan 3, 2019 at 1:20 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Imagine if it had more torque. The binding isn't going to change, but with a bit more torque something else will give.
  2. Jan 3, 2019 at 1:47 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Only tires, the drivetrain is one of the strongest points of the truck. I have binded vehicles with 190 ft-lbs to 610 ft-lbs. The tires simply do not have the traction/resistance needed to cause a mechanical failure. The tires will squeal and slip before gearing or anything else ever will.
  3. Jan 3, 2019 at 2:09 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I think OP needs to clarify if this ^^^ statement is an exaggeration. I have felt 4WD binding, in a manual truck, on dry pavement, and never once was it “like I slammed on the brakes”.
  4. Jan 3, 2019 at 2:30 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I think he just means the truck stopped. Sounds like binding to me
  5. Jan 3, 2019 at 2:36 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    OP has TSS of which I have no experience with. As far as I know his truck could have just gone Christine
    shakerhood likes this.
  6. Jan 3, 2019 at 2:37 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    This is often forgotten when these conversations come up I feel like. While binding is not optimal, the tires only have so much grip. They should slip well before anything in the drivetrain gives even with excellent traction but it's still bad practice none the less.
  7. Jan 3, 2019 at 4:00 PM
    Mack7n
    Mack7n [OP] Well-Known Member
    Josey
    Old Town, ME
    2018 Tacoma TRD Sport DCSB 6M BBP/2018 T4R TRD Pro Calvary Blue
    I was going really slow speed, maybe 2-3 mph, and it jerked to a stop. So yea, slamming your brakes feeling. If I had been expecting it to do that, I'd have put more into the throttle. Just never felt a vehicle bind as badly as this did, which I'm wrapping up to low torque at low rpm. Guess next time in 4wd in a parking lot, I'll just keep it wound up around 3500, shouldn't have issues aside pedestrians dodging me. *sorry sir, don't want it to stall out on me, so watch your ass*
  8. Jan 3, 2019 at 4:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    There is no question here. The guys answered your question correctly with binding. You must never use 4WD if you haven't experienced this in 20 years. I last experienced it... Saturday lol.
  9. Jan 3, 2019 at 5:21 PM
    Mack7n
    Josey
    Old Town, ME
    Haha, I've experienced it, just not this dramatic. This godamned truck is a drama queen I guess.
  10. Jan 3, 2019 at 5:53 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Binding occurs because, unlike an AWD vehicle, there is no center differential. In 4WD, all 4 wheels are turning at the same speed. That's fine in a straight line or when your on a low traction surface. But the moment you turn, you change the path of every wheel. The vehicle is a single unit, and as such, is always moving at the same speed as a unit. But each wheel now wants to move at a different speed based on it's new path. Inside wheels will turn slower and outside wheels will turn faster, as they have further to travel within the same time frame. You don't really notice this because the front and rear differentials "differentiate", allowing the wheels to turn at different speeds .
    However, since there is no center differential to "differentiate" between the front and rear axles, they are now trying to turn together at the same speed as the vehicle turns. This is not possible. The front and rear will fight each other...each trying to turn at whatever speed is required. The tires will grip, lose grip, grip, lose grip. That's the binding your hearing and feeling.
    Binding = bad. Don't do it .
    Mack7n[OP] likes this.
