4wd issue...wont engadge in 4low, dash beeps and light flashes
Discussion in 'New Members' started by easyrdr869, Jul 18, 2012.
  1. Jul 18, 2012 at 1:57 PM
    easyrdr869
    easyrdr869 [OP] New Member
    09 toyota tacoma
    I just purchased a used tacoma which i love. its a 2009 double cab, before i bought the truck it was inspected as part of the purchase agreement. the 4wd in my truck does work when put into 4hi but when put into 4low the light just flashes and it beeps at me... ive had it sitting still in neutral, ive turn the wheels left to right and i have krept foward and backward and it does not stop beeping and flashing and the 4low doesnt ingadge at all... need help trying to figure this out please.
  2. Jul 18, 2012 at 2:05 PM
    BamaToy1997
    Bill
    Navarre, FL
    I will be looking up information as I can, but I need more info. Manual or automatic? What size engine? Thank you.
    Are you following the proper procedure?
    According to service manual information, you must press in the switch when changing into low gear. Others feel free to correct me if I am wrong, as I am only going by what the service manual says.
  3. Jul 18, 2012 at 2:08 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    If it beeps initially when putting it in 4L, take it out of 4L, and switch it back into 4H. Drive forward and back a few feet, put it in neutral, then switch it to 4L again. Repeat.
    Once 4L beeps, it won't try to engage until you go back to 4H and neutral, then back to 4L again.
    EDIT: You have a manual trans. Refer to others with a manual trans.
  4. Jul 18, 2012 at 2:11 PM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2024 Tacoma TRD Off Road
    The clutch has to be all the way to the floor, even in neutral.
  5. Jul 18, 2012 at 2:15 PM
    Hydrolai
    Hydrolai Well-Known Member
    Johnny
    friendswood
    trd off road 4x4
    Firestick NGP Uniden 520 PROXL BadaBling! 6k Hid Plasti-Dip Wheels/Badges Leds Bed Lights
    2wd>Neutral 4HI (4H blinks then stays on solid=engaged)>move fwd, stop Neutral 4L> beeps beeps >drive fwd till it engages> if not engaging then idk. thats how it works in mine. have to be locked in 4hi before i can get to 4Lo
  6. Jul 18, 2012 at 2:19 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    And when he says all the way he means push it as far as it can go. There's a pressure switch that you have to hit. Completely stopped and clutch all the way in and it'll lock in low
  7. Jul 18, 2012 at 2:53 PM
    easyrdr869
    09 toyota tacoma
    the truck is a 4.0 litre v6 with a 6 speed standard shift
