4wd issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by emperez1978, Jul 3, 2021.
  1. Jul 3, 2021 at 6:09 PM
    emperez1978
    emperez1978 [OP] New Member
    2017 SR5lb
    Stock
    So.. my 2017 SR5 has an issue when I put it in 4 hi. It has a hard time moving as if the breaks are stuck, but once I put back on 2wd it’s fine. Anyone experiencing this issue
  2. Jul 3, 2021 at 6:13 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    If the breaks are stuck then something is already broken. I use brakes to stop my truck.
    Is your 4WD indicator light flashing??
    What is the method you are using to engage 4WD?
    Skydvrr likes this.
  3. Jul 3, 2021 at 7:51 PM
    Yem
    Yem Member
    2020 MGM TRD Pro MT
    Are you turning on dry pavement with 4wd on? It will cause binding and you can break all kinds of stuff
    beergeek, BSFord, Skydvrr and 4 others like this.
  4. Jul 3, 2021 at 7:53 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I would bet so much money this is what’s happening.
  5. Jul 4, 2021 at 5:01 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    That would be the only reason other than something is seriously wrong when on a dirt road or ice/snow.
    Chew likes this.
  6. Jul 4, 2021 at 8:21 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    OP, ummm.... you sure you aren't going into 4LO? The lower gearing could make you think "it has a hard time moving".
    If something was broken... you'd know. There'd be other symptoms.
    ORtoCOTaco, Coma4by and wilcam47 like this.
  7. Jul 4, 2021 at 9:05 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    How much is so much? :spy:
    tcjacado likes this.
  8. Jul 4, 2021 at 10:21 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Different size tires, or one or more lower than the rest, can cause the symptoms.
  9. Jul 4, 2021 at 10:39 AM
    SpanishTaco
    SpanishTaco Well-Known Member
    CT
    2015 Blue DCSB TRD Sport
    How often do you engage 4WD? When I picked up my truck a few years ago (used and sitting about 4 months before I bought it), my 4WD was very hard to engage. After cycling a few times, it smoothed out. I turn on (4hi, 4Lo on dirt roads) once a month to make sure things shift as they should.
  10. Jul 4, 2021 at 12:13 PM
    zoo truck
    None
    I noticed selecting 4wd on my old gen1 tundra could be somewhat of an issue if i didn't use it for months. It was always on the clunky side engaging, and disengaging. These gen3 tacoma 4wd systems are slicker than goose chit on a wet lawn. Mine is immediate in 4wd hi, or low when switched...same when disengaging. I just make sure to use it a few miles a month.
