4wd issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DHARDEE, Jun 20, 2019.
  1. Jun 20, 2019 at 8:23 AM
    DHARDEE
    DHARDEE [OP] New Member
    2008 tacoma
    I have replaced the front diff actuator the transfer-case motor cv axles selector switch and the module on my 2008 Tacoma and the 4wd still wont go in. It will light up on the dash recognizing but still will not lock in. Any ideas on what else would be the cause of this issue?
  2. Jun 20, 2019 at 10:44 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    There are several threads on this subject--I generally read them all because mine has acted up. I changed my pc a while back and failed to save the links. One suggestion was that limit switches (on the transfer case, I believe) could be at fault.
    Good luck. If you find the cure, let the rest of us know.
  3. Jun 21, 2019 at 5:24 AM
    Luna3
    Luna3 Well-Known Member
    Democratic Socialist State of New Yorkistan
    AS Azreb says, dig through the forum. Some have fixed actuators in the driveway, otherwise can get $$$.
    I had a rodent chew my wiring, not cheap.
  4. Jun 21, 2019 at 5:31 AM
    Taco'09
    Taco'09 Well-Known Member
    OP, do you have a VOM meter and feel reasonably confident about using the thing? If so Ill send some diagnostic info to you.
  5. Jun 21, 2019 at 6:58 AM
    DHARDEE
    2008 tacoma
    Turns out the guy i bought the truck from swapped wires around trying to rig it. So after 2 weeks of searching and replacing ive got a completely brand new 4wd system
  6. Jun 21, 2019 at 7:06 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    I've had issues with my '14.....
    going to low range and back out is a real PIA
    Going to have my mechanic bud take a hard look at it
    Plenty of info here if you dig around.....
    Just too bad such a great truck & this seems to be a real issue
    Yes....they can be fixed !
