4WD light blinking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SexyTaco, Apr 2, 2016.
  1. May 15, 2019 at 2:06 AM
    ScenicCityOverland
    ScenicCityOverland Well-Known Member
    Alex
    2015 Inferno Orange Tacoma TRD Pro
    Huh, mine is doing the same thing! Glad it’s not the only one...
  2. May 20, 2020 at 3:53 PM
    krn_taco90
    krn_taco90 Well-Known Member
    Jonathan
    2019 Super White Tacoma TRD pro
    RRW Rock sliders/Front pro grille lights
    bro mine too !!! i'm actually i'm on my way to the dealer seee if my warranty covers it
  3. Aug 4, 2020 at 10:25 AM
    000doodie000
    000doodie000 Well-Known Member
    J
    2015 Taco TRD Off-Road
    Many and always modding Wheels Suspension lift Armor Electrical gadgets etc...
    Did they cover it?
    I am at the dealership getting mine fixed. I'm still under warranty, and I figured that the light/actuator was clearly part of the drive train components.
    Heh, I guess I will know in a few hours.
  4. Aug 4, 2020 at 10:27 AM
    000doodie000
    J
  5. Aug 4, 2020 at 5:25 PM
    000doodie000
    J
    Yup. Extended warranty covered it. Cost me $100 (for deductible) it would have cost $979 at stealership.
  6. Aug 5, 2020 at 1:27 PM
    mea4dxl
    mea4dxl Well-Known Member
    NY/NJ
    2012 Access cab 2wd
    lose wire
  7. Aug 14, 2020 at 1:25 AM
    krn_taco90
    Jonathan
    OKAY HERE YE; so my dealership fucking called and said 1500 for my actuator to be fixed i said you're out of your damn mind the part only cost 309-409 if that!! and btw i took my actuator out today guess what i got it to work but i put it in the wrong groove of the diff so it won't lock but will fix tommrow no matter how corroded the motor was it still ran when we ran power to it;and they put no diff oil when they tried to fix it those so called "master mechanics" is retards at orange toyota they suck and shaun the so called master tech/manager is a liar two faced scum! DEALERSHIPS ARE NOT THERE TO HELP YOU THEY'RE GOAL IS TO ROB YOU OF ALL YOUR MONEY! THATS WHY THEY CALL THEM "STEALERSHIPS" instead of "DEALERSHIPS"
  8. Aug 14, 2020 at 1:27 AM
    krn_taco90
    Jonathan
    ITS ALWAYS A LOOSE WIRE THOSE IDIOTS AT DEALERSHIPS DONT KNOW ANYTHING ABOUT TACOMAS MAYBE CAMRYS AND COROLLAS BUT TACOS NOPE
  9. Aug 14, 2020 at 9:18 AM
    000doodie000
    J
    Toyota warranty covered mine.
  10. Aug 14, 2020 at 9:43 AM
    krn_taco90
    Jonathan
    dude you're so lucky fuck those dudes
  11. Aug 14, 2020 at 12:08 PM
    000doodie000
    J
    If you are still under warranty. I’d try a different Toyota dealer.
  12. Aug 14, 2020 at 12:43 PM
    krn_taco90
    Jonathan
    okay thanks
  13. Apr 14, 2023 at 8:40 PM
    2020tacosauce
    2020tacosauce Member
    Victor
    2020 tacoma off road
    I have this exact same problem on my 2020. Did anyone ever find out the problem?
  14. Apr 14, 2023 at 8:55 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    the 2020 (3rd gen) 4wd system is a little different than the 2nd gen system, it can be diagnosed with a scan tool that can communicate with the 4wd ECU. 2nd gens had to be diagnosed with a meter and some knowledge on system operation as they had no provision to communicate with a scan tool.
    The thread below in the the 3rd gen section has some info on the 3rd gen 4wd system.
    https://www.tacomaworld.com/threads/4wd-actuator-troubleshooting-transfer-case-and-add.578262/
    2020tacosauce[QUOTED] likes this.
  15. Apr 14, 2023 at 11:44 PM
    #35
    2020tacosauce
    Victor
    So should I just get it scanned first?
  16. Apr 15, 2023 at 2:49 AM
    #36
    2020tacosauce
    Victor
    Did you ever figure out the issue. I'm having the same exact issue as you right now
  17. Apr 15, 2023 at 8:24 AM
    #37
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That would be the easiest thing to do but most generic scanners aren't going to talk to the 4wd system.
    The OP of this thread hasn't been online since 2018 so I doubt they will ever reply, you would probably get better help in the thread I posted above or by posting in the 3rd gen section of the forums.
    I'm familiar with the 2nd gen (05-15) system but I have studied the 3rd gen system very little although it appears to operate very similar to the 2nd gen and should be much easier to diagnose with the correct scan tool that can can read codes and data from the 4wd system.
    In any case every truck with a flashing 4wd light could be a different problem, there are some common things that fail but without proper testing the flashing 4wd light just means there's a problem with a part of the system not hey replace this part and all your problems will be solved. What fixes one truck may not fix yours and likewise what fixes yours may not fix the next one.
  18. Apr 15, 2023 at 9:18 AM
    #38
    2020tacosauce
    Victor
    Good to know. Do you recommend a good reasonably priced scan tool?
  19. Apr 15, 2023 at 9:49 AM
    #39
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It's really hard to say in the aftermarket world, what works well on one vehicle may not work well on others but the current offerings from Autel, Launch, and ThinkCar seem to have about the best coverage in the aftermarket right now.
    I listed a few in the post I made in the thread below, I haven't had any opportunity to spend any time with any of my scanners on a 3rd gen truck yet so I'm not sure what coverage is like on them but 2nd gen systems are pretty much fully supported in the aftermarket mid to high end tools.
    https://www.tacomaworld.com/threads/obd2-that-reads-detailed-engine-stats.786637/#post-28147893
  20. Apr 15, 2023 at 1:15 PM
    #40
    2020tacosauce
    Victor
    I figured it out. It was the 2wd low range mod that was trigger it. Took it out and the light went away
    Dm93 likes this.
