4wd light
Discussion in '1st Gen. Tacomas (1995-2004)' started by jobrien, Jan 11, 2011.
  1. Jan 11, 2011 at 7:54 AM
    jobrien
    jobrien [OP] shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    my in dash 4wd light doesnt come on anymore anyone know why and how i can correct this problem
  2. Jan 11, 2011 at 4:31 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
  3. Jan 11, 2011 at 6:40 PM
    bivey
    bivey Well-Known Member
    Mine doesn't come on every time I put it in 4wd. Maybe if you get yours figured out. I can figure mine out.
  4. Jan 12, 2011 at 4:20 PM
    clarkie152
    MA
    2016 4Runner Trail
    do you feel it engage?
  5. Jan 12, 2011 at 5:56 PM
    bivey
    Yes. Its like the bulb has a short in it.
  6. Jan 12, 2011 at 5:58 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    i have the same thing, sometimes it lights up sometimes it doesnt but everytime i feel it engage
  7. Jan 12, 2011 at 7:52 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    screw the light, just listen to your truck, you'll know if its in 4wd or not
  8. Jan 14, 2011 at 6:43 PM
    clarkie152
    MA
    2016 4Runner Trail
    time to tear apart your dash and replace the light then to see if it solves the problem. Just because the light isnt on, doesnt mean your not in 4wd though. it just reminds you, should you forget (somehow). Id say replace it if you have a really boring afternoon ahead of you :)
