4WD Lo 4 audible alarm 2010 SR5
Discussion in 'Technical Chat' started by offgrid, Sep 5, 2010.
  1. Sep 5, 2010 at 7:49 PM
    offgrid
    offgrid [OP] Member
    offgrid
    calif
    2010 tacoma sr5
    When I switch into "lo-4" the warning light "lo 4" comes on with a nonstop audio beep. Is there something wrong? If not, can I have the dealer turn it off. I live off-grid and use lo 4 often. Thanks Tacoma World
  2. Sep 5, 2010 at 7:52 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    it means 4lo hasnt engaged. Your a manual so you need to have it in neutral and have the clutch depressed.
  3. Sep 5, 2010 at 8:06 PM
    offgrid
    offgrid [OP] Member
    offgrid
    calif
    2010 tacoma sr5
    Answering my own inquiry I read the manual. Ya gotta depress the clutch and not just turn the 4WD switch. Newbie idjit i iz.
  4. Sep 5, 2010 at 8:06 PM
    ktmrider
    Junk
    dont worry about it, thats what this forum is here for. Also welcome to TW
  5. Sep 5, 2010 at 8:08 PM
    offgrid
    offgrid [OP] Member
    offgrid
    calif
    2010 tacoma sr5
    Yo Andrew H. Is that how you sign all of your posts....with a rant and an expletive. Really?
  6. Sep 5, 2010 at 8:23 PM
    padykman
    padykman Active Member
    Paul
    Meridian, Idaho
    10 Dbl Cab TRD 4x4
    Leer Shell Outlet plug in cabin
    Without looking at the manual what do I need to do with automatic trans to stop the alarm. Apparently the one time I thought I was in 4wd low I was not.
  7. Sep 5, 2010 at 8:27 PM
    ktmrider
    Junk
    put it in neutral and stop moving
    EDIT: engage 4hi first then^
  8. Sep 5, 2010 at 11:22 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Our brains sometimes don't see what is there... the book says NEUTRAL, and our brain says PARK is the same thing... so we try and go into L4 while in PARK. No bueno... move the shifter to N, the rotate the dial into L4... ta-dah!
  9. Sep 7, 2010 at 8:49 PM
    padykman
    Paul
    Meridian, Idaho
    10 Dbl Cab TRD 4x4
    Ok now I do remember reading the manual and I am now sure that I was a victim of trying to go into 4wd lo from park not natural. Now I know. Thanks for all the help TW people.
  10. Sep 7, 2010 at 8:51 PM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    it's a quote from a different thread man. Andrew H hasn't posted in this thread :)
