4wd lo and 4wd hi?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by switchfoot177, Dec 24, 2008.
  1. Dec 24, 2008 at 8:06 AM
    switchfoot177
    switchfoot177 [OP] Member
    Marietta, GA
    98 Prerunner
    whats the difference between 4wd lo and hi? and when would you use them?
  2. Dec 24, 2008 at 8:15 AM
    98tacoma27
    Ben
    Not Beech Creek
    Basically the gearing.
    4LO is used for conditions like rock crawling and extreme low traction. It is also used for freeing heavy, stuck loads like pulling a stump. Typically it is only used on an as needed basis. 4HI is used for everything in between. Things like mudding and snowy/icy roads or you are just out tooling through the woods. If you can't get unstuck in 4HI then you would use 4LO.
  3. Dec 24, 2008 at 8:26 AM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    exactly what he said but also keep in mind u don't want to use 4lo if u go over 20 MPH
  4. Dec 24, 2008 at 8:41 AM
    40204ever
    40204ever Well-Known Member
    Caldwell, TX
    4x4 taco racing development
    How come? I do sometimes checking cows. (drive around in 4 lo above 20 mph)
  5. Dec 24, 2008 at 8:45 AM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    it could mess up your transfer case.
  6. Dec 24, 2008 at 8:47 AM
    40204ever
    Caldwell, TX
    I use 4 lo when I need to go really slow and do not want to ride the clutch. Ie: spraying fence lines and sneaking up on pigs. I also like the draft qualities of low range. I pull a 12' chain harrow to spread shit.
  7. Dec 24, 2008 at 8:48 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    sometimes I wonder what's the point on getting a pick up truck with no 4x4?
    I mean, you never know what can happen in emergency that you get stuck in Mud or whatever... I mean I'm sure FL people get Mud too. Just wondering.
  8. Dec 24, 2008 at 8:49 AM
    40204ever
    Caldwell, TX
    It better hold up, my jeep did it for 5 years and my '91 toyota did it for ten years. The '09 better do the same or I'll be pissed.
  9. Dec 24, 2008 at 8:50 AM
    beastlytaco
    Ian
    08 Access Cab SR5
    maintenance on your farm i assume. well yeah as long as your not going like over 25 or 30 all the time. you should be allright, but i would refrain from doing this All the time. as it could eventually mess up your transfer case.
  10. Dec 24, 2008 at 8:59 AM
    40204ever
    Caldwell, TX
    Yes, farm work.
    It is too rough to go that fast most of the time. I usually go back into 4 hi for speed.
  11. Dec 24, 2008 at 9:06 AM
    40204ever
    Caldwell, TX
    Spreading shit could be for recreation. It is fun hauling ass and smearing shit with a rail iron and chain harrow. Include some cold beer and some tunes, it's a party. Don't drink and drive on public roads.
  12. Dec 24, 2008 at 9:09 AM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    flowmaster 40 series, tinted windows, airaid CAI, removed 2nd filter, aries black bull bar
    if your going over 20 then use 4 hi, you wouldnt need 4 lo if you can go 20+mph
  13. Dec 24, 2008 at 9:26 AM
    40204ever
    Caldwell, TX
    I don't usually get over 20 mph in 4 lo. The truck handles it fine though. In a draft situation the low gears with the 4x4 gives you wicked torque and traction like a tractor. I use it like one when I have to.
    When I have to go really slow, I use 4 lo, you can pick a gear that you can idle in and not ride the clutch. The low range allows the engine to work easier and not get hot.
    I guess I'm saying there are more uses than what is listed in the manual for low range.
