4WD Lo indicator light flashing ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hillbillynwv, Aug 29, 2009.
  1. Aug 29, 2009 at 10:23 AM
    hillbillynwv
    hillbillynwv [OP] Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    I was backing out of a friends driveway last night and the 4WD Lo (red symbol) indicator light began flashing as soon as I started backing up.
    The 4WD switch was turned to 2WD. I went down the interstate and it flashed all the way home. When I got home, I turned the switch to 4WD Hi and the green symbol lit up but the red symbol for Lo also stayed on and continued flashing. I switched back and forth between all of them going foward and backing up and could not ever get the 4WD Lo light to quit flashing. I'm getting ready to leave here soon and drive it and I will see what is happening today. I know that the 4WD Lo is not really engaging because I was driving down the interstate going 70 and only tacking 2000 RPM's. Anyone else ever have this problem?
  2. Aug 29, 2009 at 12:50 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Never heard of this one, but since you've got an '08.. I'd take it to the dealer.
  3. Aug 29, 2009 at 12:52 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    X2 on the dealer... defiantly a warranty fix
  4. Aug 29, 2009 at 2:15 PM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    Mine did that a few times last winter after washing it at work with a high pressure hose (to get the road salt and Ice off the truck) after it dried the light went out.
  5. Aug 29, 2009 at 3:44 PM
    jgguns
    jgguns Member
    The 4-low indicator on my truck is orange. The Rear Diff-Lock is Red. Do you have a rear diff lock? If that button has been pushed in it will flash continually until you switch to 4-low unless you have done the anytime mod.
  6. Aug 29, 2009 at 8:00 PM
    hillbillynwv
    Fairmont, WV
    Damn....that was it. The freakin' Rear Diff. Lock button was pushed. I never had that button on my 1st Generation Taco and never thought about that. I must have accidently hit it when i was turning on the fog lights. Rep for you jgguns thanks for suggesting I check that out.
  7. Aug 30, 2009 at 6:47 AM
    jgguns
    jgguns Member
    Glad I could help. Since you didn't know that you had the diff-lock then I assume you haven't tried using it. If you wheel at all it can be a very useful feature especially when used in conjuction with ATRAC. As it comes from the factory it will only work when the Transfer case is in 4-low but it can be modified to lock up in any range including 4-HI.
  8. Aug 30, 2009 at 7:16 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Soon as I saw "red" I was like "he accidentally whacked his locker button".
    jgguns called it. jgguns also has good taste in truck configurations and colors.
  9. Aug 30, 2009 at 7:49 AM
    hillbillynwv
    Fairmont, WV
    I have used the button before with a heavy load of firewood going up a steep muddy incline in 4WD Lo and it crawled right up out of there without spinning a tire. Friday night when I left my friends house it had been raining and was starting to get foggy so turned on the fog lights, I must had accidently pushed the locker switch also.
  10. Jan 23, 2011 at 1:31 PM
    Tacomama
    Tacomama New Member
    Sherry
    Cincinnati
    SR5 v6 TRD
    All leather interior, heated seats, sunroof, A.R.E. paint matched tonneau cover, roof rack,
    Thank you so much guys! I know this was an old post but after using my 4wd for about a week during a winter storm, the red light was flashing and I couldn't get it to stop. Had already started trying to line up an alternate ride for next week so I could drop my Tacoma off at the dealer for repair. Decided I'd check Tacoma World as a last ditch effort before scheduling with the service dept. Saw this thread and ran out to the garage and sure enough the dang rear difff switch was on!!! Thanks again, you saved me time, money, and aggravation!!!:)
  11. Jan 23, 2011 at 10:18 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    A-TRAC wasn't on Tacomas until 2009 model.
    Also, the A-TRAC works excellent alone (without the rear locked)... In fact, A-TRAC shuts off above 3 mph with the rear locked. Consider the locker as a back up and always wheel in L4 with A-TRAC on for max. traction. Toyota warns us the rear locker is for emergency use only to get unstuck and not use over 5 mph. The A-TRAC has no such warning or limit.
  12. Jan 23, 2011 at 10:53 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    ^^ it doesnt matter to him...just another opening...lol
  13. Jan 23, 2011 at 10:57 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    This post bumped this thread ^^^
    The lovely sounding Sherry :)
  14. Jan 23, 2011 at 10:58 PM
    jhodge83
    SC
    17 XLT Sport
    we know...but it doesnt matter to some
  15. Jan 23, 2011 at 10:58 PM
    OZ-T
    Peter North
    British Columbia
    Like me :)
  16. Jan 23, 2011 at 11:00 PM
    jhodge83
    SC
    17 XLT Sport
  17. Jan 23, 2011 at 11:06 PM
    OZ-T
    Peter North
    British Columbia
  18. Jan 24, 2011 at 9:15 AM
    David K
    Not to stray from the serious advice and help offered, but am I the only Tacoma that has entirely different L4 and Rear Locker lights? How does one confuse a blinking Rear Locker light with the Low Range light? Or are they the same and those drugs from the 60's are kicking in?
  19. Jan 27, 2011 at 3:49 AM
    Tacomama
    Tacomama New Member
    Sherry
    Cincinnati
    SR5 v6 TRD
    The lights look the same (identical little pictures of the driveshaft, axles, wheels) but when I'm in 4lo its solid green and just below that light is the red blinking one for rear diff lock....Since the pix were identical, one green, one red...I was fearful that it was some warning light for a problem with my 4wd mechanism. Believe me, I'm not defending my ignorance...I recognize that mechanical problems are not my strong suit...I'm a 48 year old female who has owned my truck for less than 6 months so I attempting to LEARN...I really think most women would have just taken it to the dealer as her first effort rather than attempt to identify the problem and learn more about her vehicle...I'm sure you have areas that are not your strongest assets: empathy with others, being nice to strangers, keeping quiet if you can't say something nice...just a few that come to mind. Thank you, though for concern. I hope you have an awesome day.
  20. Jan 27, 2011 at 7:37 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Congrats you just met David K :D
