4WD Lo Light Blinking... Has anyone else had this problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HBMurphy, Jun 3, 2010.
  1. Jun 3, 2010 at 6:38 PM
    HBMurphy
    HBMurphy [OP] Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Lo light blinking, Actually in Lo Gear (can tell from experience of being in low), locker won't engage and ATRAC won't come on....
    Turned out to be this... Time for some Silly Cone and solder!!!
    If you had this problem what was your solution?
  2. Jun 3, 2010 at 7:07 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Not my solution but a damn good one.
    Manual T-Case from an FJ:p
  3. Jun 3, 2010 at 7:10 PM
    HBMurphy
    Paul
    So California Coast
    None
    I think taking that sucker out, solder and silly cone may be a bit easier... certainly not as good as your solution but about 40 hours easier! :)
  4. Jun 3, 2010 at 7:14 PM
    Jason'sLawnCare
    Certainly easier. Just seal that sucker up crazy good.
  5. Jun 3, 2010 at 7:37 PM
    JayJay
    JayJay Well-Known Member
    Pacific Northwest
    08'Taco.DC,SR5.TRD. Off Road,Manual 6Spd.
    3 inch lift Rev Tek Bilstien shocks .Westin crome side nerf bars (steps) Toyo 285-16" , HID High/Low 4300k ,yellow fogs 3000k, Lear cap 100 XQ , Thule Tracker 2 roof rack , Bed Rug bed liner ....
    two part glue (3m) its been known that silicone atracts water and breaks down ..... they used to use silicone on 60's an older car windsheilds ,thus rust from atraction of water and break down of product... now they use urathane based for glass....... electrical and silicone ????? , look for a urathane based two part epoxy 3m .... I been a body and frame tech for 23 yrs .... (or just get a new pigtail from toyoyta ) ... good luck my friend ...... silicone will work but it breaks down .........
  6. Jun 3, 2010 at 7:49 PM
    HBMurphy
    Paul
    So California Coast
    None
    That's why I love this place! Very good! - Wats 'bout Permetex Right Stuff?
  7. Jun 3, 2010 at 7:52 PM
    Jason'sLawnCare
    Wow great advice. Your a top notch member here in my book now.
    x2.
  8. Jun 3, 2010 at 8:04 PM
    HBMurphy
    Paul
    So California Coast
    None
    You have that right! :) :D We need to get him a raise and on the special TW bonus program!
  9. Jun 3, 2010 at 9:14 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    What about GE Silicone II? I thought that stuff was water proof.
  10. Jun 4, 2010 at 8:50 AM
    JayJay
    Pacific Northwest
    Yes water can not penatrate the silicone but it breaks down and yes it attracts water .........after breakdown , no worky worky !!!! and are you going to check it every few months or just use the right stuff ???? good luck WOOOOOOOOOO HOOOOOOOOO !!!!! :D
  11. Jun 4, 2010 at 8:52 AM
    HBMurphy
    Paul
    So California Coast
    None
    No - I will take your advice and use the 2 part epoxy! - I just love the RightStuff for gaskets! :cool: :)
    Thanks again!!!
  12. Jun 4, 2010 at 10:06 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You know that thing is like $10 and 5 minute to replace :D
    EDIT but if you glue harness to it its going to cost you over $200 to replace and few days of work :D
  13. Jun 4, 2010 at 10:07 AM
    HBMurphy
    Paul
    So California Coast
    None
    Well hell at that price I will order one today! :) Thank you! (and make a trail spare for my tool box!)
  14. Dec 16, 2013 at 9:22 AM
    cookee62
    cookee62 Well-Known Member
    Lake Mary, FL
    06 DBL Cab
    URD SS, URD Y-Pipe, DTLT Headers, 3" URD Cat Back, Fox 2.5 CO, TC UCA, Fox Rear Resi, SS brake Lines, All pro 1.5" leafs, Halo Projector Headlights, WE Bead-lock Rims, 33 BFG AT, No Sway Bar
    Is that a pic of the your transfer case or front diff. Also can't see in the pic but what are u silacone and soldering
    Thanks
  15. May 16, 2014 at 11:59 AM
    HBMurphy
    Paul
    So California Coast
    None
    Nearly four years later the Right Stuff is still keeping it together and working. :)
