4wd LO range warning beep?
Discussion in 'Technical Chat' started by 2_wheels, Jun 13, 2011.
  1. Jun 13, 2011 at 6:56 AM
    2_wheels
    2_wheels [OP] Well-Known Member
    Coeur d'Alene, ID
    06 Tacoma TRD Sport 4x4 dbl cab
    Ok, I finally used 4wd LO range and the truck emits a really annoying warning beep through the speakers.
    Has anyone a fix for this? It's so loud I said F%&^ that and went back to 4wd HI.
    My truck is a sport model with the VSC.
    Thanks for any suggestions.
  2. Jun 13, 2011 at 7:01 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It only beeps when it's not engauged and 4lo is selected.
  3. Jun 13, 2011 at 7:05 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You have to put it in neutral to engage 4lo. It only beeps when something is not right.
  4. Jun 13, 2011 at 7:21 AM
    2_wheels
    Coeur d'Alene, ID
    That's what I did, stopped the truck, put in neutral and select 4lo. it started beeping immediatley but it was in 4lo. I was only in it for a brief moment and went back to 4 hi. Any ideas? did it just not fully engage?
  5. Jun 13, 2011 at 7:27 AM
    Pugga
    Massachusetts
    Hmm.. not sure, hopefully someone else responds with ideas. Mine did that when I forgot to put it in neutral. Usually if I have 4hi engaged, then stop, put it in "N" and select 4lo, I've never had a problem. I'm sure others will chime in.
  6. Jun 13, 2011 at 7:32 AM
    2_wheels
    Coeur d'Alene, ID
    Yeah, I was in 4hi for like 10 miles on a rocky slow trail. I came to a section and went to 4lo. It was in low, I could feel it.
    Well anyway it obviously wasn't right if that's not normal. I'll see if it was me:confused:. I hope it was just driver error!
    Thanks!
  7. Jun 13, 2011 at 7:58 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Did the 4LO light on the dash go solid or keep blinking?
  8. Jun 13, 2011 at 8:40 AM
    2_wheels
    Coeur d'Alene, ID
    The light went solid.
  9. Jun 13, 2011 at 8:44 AM
    Pugga
    Massachusetts
    If I recall correctly, I'm pretty sure if the light goes solid, you're engaged. Usually it blinks if something is wrong or it can't engage. Sounds funky.
  10. Jun 13, 2011 at 8:59 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    try putting it in park, take your foot off the brake (alligns gears), foot back on brake, shift into neutral, then shift it to 4lo.
  11. Jun 13, 2011 at 11:11 AM
    OffroadToy
    I've never heard of this before...how does taking your foot off the brake while in park align the gears?
  12. Jun 13, 2011 at 11:21 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    someone told me this years ago. i've never really thought about it, but whenever mine won't shift, i do it and it's never failed :notsure:
  13. Jun 13, 2011 at 12:19 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It happens to all of us if we are going into L4, and don't have the tranny in the correct position.
    Neutral (N) isn't the same as Park (P) when going into or out of L4. The beeping means you are in (P) Park when trying to go into L4... Shift to (N) Neutral and re-try.
  14. Jun 13, 2011 at 12:21 PM
    Pugga
    Massachusetts
    He was in neutral.
  15. Jun 13, 2011 at 12:27 PM
    David K
    I know he said he was... but it wouldn't be the first time we subconciously think of Park and Neutral being the same thing... Just a double check for him to try before going to the mechanic.
  16. Jun 13, 2011 at 12:49 PM
    Pugga
    Massachusetts
    That's actually pretty true... I remember the first time I put mine in 4lo while still in drive and damn, lights were flashing, bells went off, I thought I initiated the self-destruct button and was waiting for the count down!!
  17. Jun 13, 2011 at 10:08 PM
    2_wheels
    Coeur d'Alene, ID
    Hey again here's an update to my dilema.
    remember that this was the first time I've ever needed 4LO in this Tacoma and I've owned it for 5 years. I changed the differential fluid about 2 months ago;
    I did stop and shift to neutral, all that. This isn't my first 4x taco:) or other 4x for that matter.
    So after work today I stopped on a flat dirt road.
    I stopped completely, took my foot off the break and while in nuetral I shifted into 4lo, I wasn't moving forward or rearward while in N.
    Everything was fine..:)
    NO beeping or anthing different. The problem was I'm guessing the terrain?
    Here is where I think the difference took place; originally when I tried it was in total back country trails in Death Valley and the wheels were cranked to one side and I needed some LO range torque to get around this uphill rock garden, I started spinning and then backed off and did the 4lo deal.
    I think I'm ok now so thanks for everyone chiming in. Maybe I just needed a few more feet for my low range to kick in/??
    Either way thanks to all of you for your replies.
    rreddogg likes this.
  18. Jun 14, 2011 at 6:46 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I know mine is touchy. If it won't engauge on the first try, I move an inch or two and try again. Sometimes it goes right in. It has gotten easier since the first few attempts. Just gotta get it broken in.
    Glad it's working for you!
  19. Jun 14, 2011 at 6:50 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    i fuckin love my manual transfercase shifter.
  20. Jun 14, 2011 at 6:56 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I hate you and your two shiftin' shit... More so jealous:rolleyes:
