4wd LO range warning beep?
Discussion in 'Technical Chat' started by 2_wheels, Jun 13, 2011.
  1. Jun 14, 2011 at 7:21 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
  2. Jun 14, 2011 at 7:40 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    ??? Wha' happen?
  3. Jun 14, 2011 at 7:45 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    i dont know what your talking about.
    if i were to own a 2nd gen id look into swapping a manual tcase since i always hear about random issues with the electronic crap.
    but this is why i have a 1st gen :p
  4. Jun 14, 2011 at 7:54 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    manual hub swap :D
  5. Jun 14, 2011 at 8:04 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    oh just looked it up, i thought the hubs were auto disconnects.. probably why its not ADH lol so yeah your right but the majority of issues come from that little electronic switch on the tcase right? forgot what its called
  6. Jun 14, 2011 at 8:13 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    old tundras and sequoias have a button to go to 4wd and a stick to change the transfer cast from 4hi to N and to 4lo. i think my fiend's 1st gen is stick only though
  7. Jun 14, 2011 at 8:15 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    theres a few 1st gens that have that set up as well, i thought it was the weirdest thing when i saw it cause i thought all 1st gens used the regular stick shifter.. i prefer the j-shifter
  8. Jun 14, 2011 at 8:19 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    so you shift to the side to engage 4x4, and then forward and back to go between hi, n, and lo correct?
  9. Jun 14, 2011 at 8:25 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    mine is a backwards "J" shape, starting at the top 2wd, down 1 is 4hi, down 2 is neutral, and over and up is 4low
  10. Jun 14, 2011 at 10:56 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I think the difference might have been you had your wheels cranked to one side the other day...works best when they're pointed fairly straight in my experience. The gears just need to get lined up. I've had to crawl slowly forward or backward while moving the steering wheel back and forth a bit, put back into neurtral and try again to get 4L0 to engage.
  11. Jun 14, 2011 at 11:03 AM
    RedskinRedTaco
    RedskinRedTaco Well-Known Member
    Paul
    Virginia Beach, VA
    07 TRD 4x4 Offroad Crewcab
    Trifecta folding Touneau Cover, 275/70/16 LTX M/S, Running Boards, Dynamat, tint, Alpine W404 Video system w/ backup cam, Sirius Sat, Polk Audio Component Speakers frt and back, Alpine 4x50 amp. Billy's 5100's set @ 1 3/4, 1" rear blocks, Rear TSB, trimmed frt mud flaps 4", TRD Exhuast, K&N filter. Electric Brake.
    you have to put it in neutral and have the wheel straight. if the wheels are turned it wont lock in and the buzzer will go off.
