4wd Lo Steep Hill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chemi19, Nov 6, 2022.
  1. Nov 6, 2022 at 3:33 PM
    Chemi19
    Chemi19 [OP] Active Member
    Hi
    So I have a 2019 TRD Off Road dbcb manual.
    I just got to an Airbnb and the final bit of road to it is super steep, the truck totally bogs down going up it unless I smoke the clutch.
    The hill is paved with a 90° turn at the end.
    Is it okay to use 4wd lo to go up it? Would it damage the t case? What are my options, a broken t-case or smoking the clutch?
    Thanks for your help.
  2. Nov 6, 2022 at 3:35 PM
    Bishop84
    Bishop84 Well-Known Member
    It will Buck a bit but will be fine. Use 4lo and save your clutch.
    No one has broken anything on any Toyota truck by using 4x4 on dry pavement. It just feels bad.
  3. Nov 6, 2022 at 3:38 PM
    duckytw
    duckytw Well-Known Member
    You'll be fine for the vacation. Might want to look into the 2lo mod.
    Bob1971, JDKred, cryptolime and 2 others like this.
  4. Nov 6, 2022 at 3:41 PM
    Chemi19
    Thank you so much. It’s really a short distance, maybe 500 yards, but I always keep hearing that the transfer case will explode if used on dry pavement.
  5. Nov 6, 2022 at 3:41 PM
    perterra
    perterra Well-Known Member
    Tejas
    What do the owners normally use to get into it if you have to resort to low range?
    Chew likes this.
  6. Nov 6, 2022 at 3:42 PM
    Chemi19
    Even on a tight turn? I’m going super slow but it’s super tight
  7. Nov 6, 2022 at 3:43 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I second the 2lo mod. Easy to do and well worth the effort to use it in reverse on any sort of incline. Will save your clutch.
    OZ TRD, Toy_Runner and Canadian Caber like this.
  8. Nov 6, 2022 at 3:43 PM
    Chemi19
    I assume an automatic, or a vehicle with more torque. I love my Tacoma but the torque is non existent
  9. Nov 6, 2022 at 3:44 PM
    Chemi19
    Is this something I can do without buying the kit? I’m outside if the country and doubt I can get it shipped here
  10. Nov 6, 2022 at 3:45 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    The clutch is meant to be a wear item.
    You may be slipping it more to get going but once you're moving and it's fully engaged 1st gear will have enough to get you going.
  11. Nov 6, 2022 at 3:45 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    It is possible to do it without the kit. It would require some relays, some harness modifications and a power resistor.
    Edit: and switch.
  12. Nov 6, 2022 at 3:47 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Does it bog if you keep it floored in 1st gear (maintaining > 4000 rpm)?
  13. Nov 6, 2022 at 3:48 PM
    perterra
    Tejas
    Glad I bought an automatic I guess, who knew a V6 with 4.30 gears smoked the clutch on a paved road going into a rental.
    D. Lengua and Hooper89 like this.
  14. Nov 6, 2022 at 3:49 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Is it easier in reverse? Or is that gear too tall too?
  15. Nov 6, 2022 at 3:49 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    Go slow and don't unnecessarily load up the diff and it'll be fine. It'll hop, skip, and bump making the turn, so don't give it too much torque, just let it slowly skip the tires
  16. Nov 6, 2022 at 3:58 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I’ll 3rd the 2lo mod (though it doesn’t help you now).
    It reminds me…. We did an Airbnb in Tennessee recently but in my wife’s rdx. It was steep enough that it made me think of those guys smoking 3rd gens on hill climbs.
  17. Nov 6, 2022 at 4:00 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Strange I have only heard it will explode but never a post on a broken one.
  18. Nov 6, 2022 at 4:03 PM
    Chemi19
    No but will definitely smoke the clutch
  19. Nov 6, 2022 at 4:03 PM
    Chemi19
    This is also in a third world country. Going thru El Salvador now.
    OZ TRD, SH10151 and DingleTower like this.
  20. Nov 6, 2022 at 4:04 PM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    I was at an Airbnb in Wyoming this summer that I either had to send it or use 2lo or 4lo to get up the driveway. It was noted in the ad for it though.
    There's a spot on my own property that I can't get a run at because of trees and have to put it in Lo to get up the hill.
    So... Send it, slip the clutch, or, put it in Lo. All have their pros and cons.
