4wd low beeping???????
Discussion in 'Off-Roading & Trails' started by Mamy, Oct 14, 2018.
  1. Oct 14, 2018 at 6:43 PM
    Mamy
    Mamy [OP] New Member
    2013 4wd tacoma
    In 4 low it alwys beeps constantly. How do I make it stop?
  2. Oct 14, 2018 at 6:44 PM
    tcjacado
    tcjacado Well-Known Member
    It sounds like it is not engaging.
    BlueFalconActual likes this.
  3. Oct 14, 2018 at 6:44 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Put it in 4 hi.
    I'm here all week.
    essjay and black coffee like this.
  4. Oct 14, 2018 at 7:47 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It will stop with it actually engages or disengages. It will flash/beep when it's trying to engage but can't. You should be going only a few MPH, preferably on loose ground, not turning or under power. I find it helps to push your 4wd button when you're coasting almost to a stop in neutral.
  5. Oct 14, 2018 at 7:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Are you shifting from 4H to 4L in Neutral ?
  6. Oct 14, 2018 at 7:57 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    This.
    You must brake fully, put the truck in Neutral, and then switch to 4L. It will engage and wont beep and you can put it into drive and go
  7. Oct 15, 2018 at 6:37 AM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    ^ this. The instructions for How to put it in 4 low are on your visor
  8. Oct 15, 2018 at 8:07 PM
    MickeyB
    MickeyB Well-Known Member
    '17 TRD OR 6MT 4x4
    Mobtown skids and sliders
    Additionally, with a manual, the shifter needs to be in neutral as well. I thought I just needed to have the clutch in, but it needs both. (Insert obligatory "I wish the transfer case had a stick as well" comment)
  9. Oct 21, 2018 at 7:52 PM
    1fun701
    1fun701 Active Member
    18 Cement TRD OffRoad
    I have a manual too, and mines still a little bit of a princess going into 4L. With mine, I found going back into 2h, rolling a bit, then going straight to 4L usually does the trick
    flyndog likes this.
  10. Oct 24, 2018 at 9:32 AM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    Mine doesn't have to be in neutral. If I'm in 4HI, I just stop the truck, press the clutch, and shift to 4LO. Doesn't matter if its in gear or not
  11. Oct 24, 2018 at 1:29 PM
    MickeyB
    '17 TRD OR 6MT 4x4
    Maybe it's the difference between 2nd and 3rd gens? I know my 1st gen just needed the clutch pressed, even if the truck was in gear. I mean, it makes sense since the truck can't get anymore in neutral (I can't pull over any farther! LOL). But there are a ton more electronics and "safety interlocks" on these newer trucks.
  12. Oct 24, 2018 at 1:31 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Must be a later model Tacoma thing...my 04 I just have to do one or the other (neutral or clutch in), doesn't have to be both.
    MickeyB[QUOTED] likes this.
  13. Oct 24, 2018 at 1:34 PM
    eon_blue
    Azusa, CA
    ..and my transfer case has a stick :D although, not the J-shift which is the most ideal...I still have to press the button on the shifter to go into 4HI
  14. Oct 24, 2018 at 1:41 PM
    MickeyB
    '17 TRD OR 6MT 4x4
    That's my biggest complaint about the 3rd gens - no transfer case lever! You can get a 3rd gen with a manual transmission and push button 4wd, and you can get a Trail 4R with an auto transmission and a manual transfer case?! :facepalm:
    eon_blue[QUOTED] likes this.
  15. Oct 24, 2018 at 1:42 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Put it in neutral then into 4L while at a complete stop. 4H can be engaged will moving under 55mph on the go which is great for snow and sand
    RON_TRD Sport likes this.
  16. Oct 30, 2018 at 3:47 PM
    jbrandt
    Justin
    My '17 4Runner has all push button, no lever, just a dial (5 speed automatic). Last time I was wheeling with it, it had trouble getting into and out of 4lo (even 4hi). I was beginning to doubt my intelligence... I was trying everything form neutral, full stop, no turns, etc... It eventually went in/came out, but it was kind of annoying.
    At least with my 04 TRD, with the t-case lever, I can "feel" it going into 4lo.
  17. Jan 13, 2024 at 2:29 PM
    LashaTrdPro
    LashaTrdPro Member
    2022 trd pro manual. 2h to 4h is very simple but to engage 4L i have to switch the dial to 4L and put it reverse and that is only when it engages 4L. Let me know if its the same for yall
  18. Jan 18, 2024 at 10:00 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    No, it's not the same. At a stop, clutch ALL THE WAY TO THE FLOOR, shift into 4LO. What gear the transmission is in doesn't matter and the truck doesn't know anyway. If it doesn't go right into 4LO just jostle the drivetrain by shifting in and out of a few gears or releasing the clutch in N and then pushing it back ALL THE WAY TO THE FLOOR.
  19. Jan 18, 2024 at 10:18 AM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    if you’re on a hill you can also release the brakes and let it roll slightly. The owners manual says 6spd tacos can engage 4Low up to 2mph.
  20. Mar 6, 2024 at 6:55 PM
    CyrusC1
    CyrusC1 New Member
    Cyrus
    2012 Tacoma 2.7 4x4
    None
    Late to the party on this..but for anyone else coming to this thread it works best for me if I don't stop at 4H first. Go right from 2 to 4lo. Works more times than not. 2014 2.7 5spd.
